Whirlpool commercial 9245h washing machine
Fluff on clothes after washing. Where is the filter to clean it?
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Posted on Jan 12, 2008
  • 490 Answers
SOURCE: fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Posted on Jun 07, 2009
Jahn27
  • 1554 Answers
SOURCE: We have a whirlpool super capacity plus washer
You did not state the complete and exact model number but based on the model number given, I assume the machine is a top loader. The closest model number I found is 6LSC9245HQO and this machine has a Magic Clean lint filter located at the bottom of the basket. Wash and rinse water flow over the filter, separating the lint from the water. The lint then spins out of the machine during the spin cycle.
The only way to access and clean the lint filter is by taking out the basket. This requires the removal of the agitator then the basket but you will need a special tool called spanner nut wrench to remove spanner nut holding the basket to the drive block.
Please indicate the exact model number of the machine for more specific advice or if you need further assistance. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 16, 2010
  • 422 Answers
SOURCE: where is filter on my hotpoint aquarius wmf540
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Posted on Oct 02, 2011
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
A great deal of fluff is appearing on the washed clothes. The machine is an LG WF-T1391TP top loader, 15kg.
If you told us the make and model of the machine maybe someone could help?
Aug 12, 2015 | Washing Machines
Where do I find the filter on a Whirlpool top loader - our clothes regularly need re-washing as are covered in fluff?
have you check the outlet drain hose for blockage? go online check your wp model for built-in filter if any. if there is one you need the washmachine schematic show the location of the filter. most of the old machine may have a panel on the backside to access. this way you can get to the filter.
Mar 03, 2015 | Whirlpool 358276 Topload Washer Water
Speedqueen does not wash clean. Always white fluff on clothes. Is there a filter to clean
Clean you 'lint filter' - see your instruction booklet or if you don't have it google your washing machine model and see where the lint filter is and how to clean it. It's usually a small pouch on top on the steel drum that you have to slide out and clean.
Hope this helps.
Jul 30, 2014 | Speed Queen speedqueen lgs37-11811
Model 3LSC8255EQ. TYPE111. When my wife uses the washing at present,and when shs removes the clothes their a lot of fluff on all the washed items,my wife has then to brush each item which takes a good...
TJIS DUE TO YOUR NEW WASHER SPINS AT AF FASTER RATE THAN OLD WASHER AND NFLUFF IS BEING EXTRACTED OUT OF CLOTHING IT WILL EVENTUALLY STOP AFTER A COUPLE OF WASHINGS OF EACH ARTICLE OF CLOTHING THIS IS NORMALL
Jan 24, 2011 | Whirlpool Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Jan 17, 2011 | LG WFT1071TP Top Load Washer
Hi i have a whilpool 5132E top load washing machine i bought second hand, my cloths collect fluff, especially the towels. Does thi model have a filter.thank you chrissie
no but it sound like the agitator has a sharp edge and chewing up the cloths feel your finger all the surface area of the plastic and feel for a gouge or rough area then get sandpaper or other type of item that will smooth it out and that should stop the fluff issue
Sep 08, 2009 | Whirlpool Washing Machines
Fluff on left on clothes
Jun 07, 2009 | Whirlpool Washing Machines
Whirlpool calypso GVW9959Q - Black stains on whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 14, 2008 | Washing Machines
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
