Question about Cameras
I have a VPC-51285 camera and my laptop wont read it at all. Restarted pc still not reading. No installation disc. How do I fix this problem?
SOURCE: PC can't read camera
We had the exact problem. The cameta may be set to web-cam mode, eather than PC. To fix:
Rotate the mode dial to Setup. Select Set-up2 menu, then select USB Con. Press OK.
Select PS and press OK.
The PC should now read the camera as a removable drive.
Hope this helps!
Ken
Posted on Feb 08, 2008
Agent Allan
  • 480 Answers
SOURCE: sony mavica trouble reading discs
Hey jadyjo,
You need to format the floppy disc by selecting file, then disc tool, and then format in the menu system. Instructions on how to do this are on page 52 of your user manual. Remember that formatting the disc will erase any images on it even protected ones. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 13, 2008
SOURCE: mY DIGITAL CAMERA IS A
This is what the Sanyo Customer Service team responded with for me, and it worked:
Take a look at the lens to see if it is crooked or mis-aligned. If it is, with the camera turned off, try to straighten the lens to see if it will click back into place. If it does, turn the camera on and off a couple of times to see if the lens will open and close as normal and then try using the camera as normal.
If the lens is not crooked or straightening does not solve the problem, the camera will need to be serviced.
The warranty coverage period is 90 days for parts and labor.
For non-warranty service, check your yellow pages for camera repair to have a local service technician take a look at the camera for you.
Please consider that the normal out of warranty labor cost can be around $ 75.00, this does not include the cost of parts and return freight upon completion of repairs.
Posted on Jan 27, 2009
SOURCE: Caplio g4 - Laptop Wont read my camera
You need a compatibility patch for your camera to work on Vista. Get it Here:
http://www.ricoh.com/r_dc/os/win-vista.html
Posted on Feb 28, 2009
pabloloco
  • 2335 Answers
SOURCE: need to reformat card for sanyo vpc-s880
I have a link to a manual for a Sanyo VPC-S870.
I hope that helps.
Posted on Oct 07, 2009
My Toshiba Model L505-S5993 laptop won't read
Hello there,
The problem is that the Drives lens is already bad and cannot read any disc, no matter the type of disc you put into it, it wont read it still. The solution is to replace the drive. Replacing it is the best way to solve the problem. If not trying to replace the lens is going to be futile as the lens for the driver is not available and when you install a new disc drive, it will have to install the drivers software.
If you replace the lens, the laptop wont be able to install the drivers of the lens as it reads it alongside the driver itself and if they are not compatible, it wont install the drivers software. So my best advice is for you to replace the CD drive.
My laptop is a typical example because my disc drive is also bad. And i had to replace the drive and not the lens.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 09, 2011 | Toshiba Satellite L500 Series Notebook
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Feb 24, 2008 | Panasonic NV-DS65 Mini DV Digital...
OS: Windows Home Premium 64-bit DVD Drive: ASUS TSSTcorp CDDVDW TS-L633C The dvd drive in my notebook isn't working correctly. I put a disc (cd, or dvd) in, and it will not autoplay or show up in My...
You can try cleaning the eye of the drive with a cotton swab and alcohol gently a few times and see if it starts reading the discs.Clean it gently in circular motions 2 or 3 times.If that doesn't work the drive may need to be replaced.
Jan 20, 2011 | ASUS N61Jq A1 Notebook
My sanyo vpc 51285 doesnt record any sound when i go to take a video, is it supposed to be like that or is it messed up???
Hi, try to open the camera and check the 'mic' if its working or not.you need todo is desolder and resolder the connection of the mic. in that case you will know the problem.
good luck
Jul 13, 2010 | Sanyo Xacti VPC-T700 Digital Camera
Lexmark X2500 wont read on the computer (2008 HP Vista).
please try reinstalling the drivers. unplug the printer from the pc, reinstall drivers. restart pc before you plug the printer back in to the pc. after restart, plug printer back in. should work. do you have the install disc for the printer? If you do, and the first fix did not work, plaug the printer into the pc. Put the install disc into disc drive. if the autoplay is running it should ask you if you want to read the files on the disc, just close this window. Then go to START-RUN(type in) DEVMGMT.MSC and find the printer option. expan and right click on the little printer and choose "UPDATE DRIVER" it will then give an option to choose from updating from a specific location or install from a specific location. choose FROM A SPECIFIC LOCATION. another window will pop up with the choice to search from removable media ie floppy, cd etc, etc. choose that option if it hasnt already. It shouls all be automatic from her on out. Good luck.
Jan 04, 2009 | Lexmark X2500 All-In-One Printer
Laptop froze so restarted it.
thankyou for your request.
it,s not necessarily the CD Disk, that it,s refering to. it may be the hard-disk.
if your having to leave the windows cd in the drive, then your hard-drive ( Disk ) may be lacking a few files on it, and reading from the cd for the missing files.
what you need to do, is format the hard-drive, then go through the re-installation of windows. when you,ve done that. ensure that all of your decive drivers are installed correctly.
if you go to My Computer/control Panel/ system/Device manager Any devices not correctly installed, usually have a yellow exclamation mark by them.
if this solves your problems, please rate as fixya.
if your still having problems, please post a reply here.
many thanks Mike @ compurepair.
Nov 17, 2008 | Compaq Evo N610C Notebook
Sanyo VPC-T850 Camera. Came with disk, but no install info on it. Can't get pix off camera...windows (XP Home)won't recognize it!
I have installed all the software on the disc that came with the camera. Connected the camera to the laptop and the laptop will not recognise. I have photo on the camera I would like to download but cannot!
Aug 25, 2008 | Sanyo VPC-C5 Digital Camera
Driver downlads
sanyo vpc-s750 digital camera don't read a sd card
Dec 13, 2007 | Cameras
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
Cameras Logo
107 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
