Question about RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only
Remove quick connect - RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only
Electric water heater stopped working
The unit doesn't like to drain without air coming in on top of water, so flushing with pressure applied is the preferred way. Be careful, see if you have power coming into unit. Turn off power and open the connection connection plate I would suspect that if the breaker is supplying power, sometime I have found that the connections are not properly made.. . If you a timer to limit operational hours take it out and go directly to romex from breaker panel.I f water starts hot and then go cool very quickly the bottom heating element and or thermostat is not working. Remove lower element cover and with power off check element resistance you can compare upper and lower element readings. From experience I never repair water heaters: time and material is more than new unit. You will need to buy element socket heating element(s) and or thermostat(s). In the end you still and old water heater.
Apr 20, 2017 | Whirlpool 28 Gallon Electric Mobile Home...
Àccubake lower element burns out immediatly when replaced with new. Twice now! No damage to element is visable but a quick flash is observed.
use a multi meter to determine the resistance of the element to see if it is still serviceable
there has to be a fault in the element holder or connections
call an electrician to run safety checks on the unit
Oct 27, 2016 | Element Water Heaters
Coffee pot is only 6 weeks old , the hot water maker stop working is there a quick fix
remove the bottom screws and check the wiring if all hooked up then no quick fix return it.
Jan 14, 2016 | Cuisinart CHW12 12-cup Coffeemaker w/ Hot...
Why does the flame shut off before a hot to warm temperature can be achieved
I would question the Thermo couple. It pretty much runs the whole show. Inexpensive quick fix. It's the small tubing that is connected to the gas valve. The other end is a bulb that sits over the pilot flame.. Remove the old and match it up at the hardware store. Install new coupler ensuring bulb is directly over the pilot flame Common iten. The thermocoupler alks to the gas valve. If the pilot flame extinguishes (goes out) the bulb cools and shuts down the gas valve so the pilot gas feed doesn't permit raw gas to accumulate, avoiding the need emergency Services. . You will not get the heater to fire until the bulb is good and hot. The red push button ,when depressed will allow the pilot flame to be lit. Hold it down until the heater fires, indicating the T-coupler has reached its operating temp.Good Luck-Ned
Sep 10, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch aq 125
Check for crossover, aka cross connection
http://waterheatertimer.org/Crossover.html
Install ordinary tank electric water heater for $250 and solve problem quick, sure and cheap
Jun 06, 2013 | Water Heaters
Where do i conect to do a gas presure test on a atwood DSI RV gas valve
Using a manifold and manometer, you connect between propane line feed and valve. A quick check at stove should give you system pressure as well.
Jun 07, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Switch left on now Atwood RV electric water heater will not heat. What needs replaced?
If no water in it when switch left on for hydro use, you probably burned out the element. They burn out pretty quick when no water. You have to shut off breaker to it for safety, and remove back cover where you see hydro cable going in to access it.
Dec 27, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
What does F-76 code mean on a Noritz M-069 panel
F76 is a communication error. It usually occurs if you connect or disconnect a quick connect cable or remote control when the tankless heater is connected to electricity. (If you have a quick connect system, make sure you only have 1 remote and 1 quick connect cable.) To get rid of the code, try disconnecting electricity for 20 seconds, reconnecting electricity, and turning the remote on. If the code returns, you may need to replace your quick connect cable, remote cable, or even remote control
Sep 14, 2010 | Noritz 6.9 Gallon Residential Tankless...
My Noritz tankless will sometimes flash 5 red quick lights which indicates to me that it's not firing and I've only succeeded in restarting it at the circuit box. What servicing needs to happen to prevent...
You are getting an error code. A 5 flash error code is typically caused by voltage supply abnormalities. If you are using a generator, battery backup, or solar electricity inverter, make sure it is supplying your heater with a smooth sine wave AC voltage.
This code can also be caused by connecting jumpers inside the unit with power connected or buildup of soot on the sensors
Feb 24, 2010 | Noritz 6.3 Gallon Residential Tankless...
I have low pressure on my Worcester Bosch 30si but I can't remember how to fill it up, please can you help?
connect filling loop from cold main too heating flow or return you,ll find teed pressure system by short quick flicks at the valve on the cold supply best of luck
Nov 29, 2009 | Water Heaters
RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only Logo
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
