GoVideo DV1130 DVD Player / VCR Combo
Problem for GoVideo DV1130 DVD Player / VCR Combo
DV1130 hooked up to TV, DVD works great. VHS has
By hotpins on Apr 25, 2009
DV1130 hooked up to TV, DVD works great. VHS has sound but no picture.
Comments:
Apr 25, 2009
- Using Pr, Pb, Y componnet cables plus R & L audio out. Chose "DVD Exclusive Out" on back of Go Video DVD/VCR player. Used Color Stream HD-1 on back of Regza 52" TV (Y, Pb, Pr, L/R Audio). DVD plays great (picure & sound). Trying to play VCR tape and no sound or picture. Removed DVD, used remote and also tried front of DVD/VCR player to click on VCR/TV. Tape actually can be rewound or FF, but no picture or sound. I am tech challenged. Thanks.
Best Solution
posted on Apr 25, 2009
Very Helpful)
TMurdock
Rank: Guru
Rating: 88%, 25 votes
If you are using RCA cables (Red Yellow White) the video (yellow) could be bad or not in the connector all the way. When the VCR mode is selected try pulling the yellow connector out then back in and see if anything changes on the tv.
If you are using another type cable let me know and I will help you diagnose.
Hope this helps
TankMurdock
Comments:
Apr 25, 2009
- Ok can you list for me the available outputs on the back of the DVD/VCR? I believe because you are using the "DVD exclusive out" it is only allowing you to view the DVD and not the VCR. I don't believe the VCR is hi def compatible. Just list the available ports on the back and I will let you know which ones to try.
Thanks
TankMurdock
Apr 25, 2009
- I think I have your solution. If you want to use the (Y, Pb, Pr, L/R Audio) for the DVD its no problem. You will need to get another set of RCA cables (red, yellow, white) for the VCR and plug them into the DVD/VCR output on the DVD/VCR player and the other end to an available input on the TV (video 1 or aux port) they will be color coded on the back of the TV so you know where to plug them in. Switch your TV input to the one that you plugged the cables into and then try a VCR. I am pretty sure this will correct your issue.
It will have to be done this way because you are using the DVD Exclusive port to view your DVD's in HD. The VCR side doesn't have a HD output so it needs another input.
I hope I explained this well and didn't confuse you, if you need anything just comment back and I will answer. This should get you going!
Thanks
TankMurdock
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GoVideo DV1130 DVD Player /
Questions and Unsolved Problems for GoVideo DV1130 DVD Player /
Do you recommend GoVideo DV1130 DVD Player / VCR Combo?
Answer
Answer
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to... (More)
Answer
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with... (More)
Answer
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a... (More)
Answer
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable... (More)
Answer
You can no longer set up a timed recording to the VCR after the digital conversion that took place... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GoVideo DV1130 DVD Player /...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
