Question about Compatible 2 Packs - Risograph S568LA, S-568LA Master Rolls
P98-25 Error code on a Riso RZ200 printer - Compatible 2 Packs - Risograph S568LA, S-568LA Master Rolls
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
How much would I pay for 2 x drums for a RZ200? Thanks
you can probably find them on ebay for about 3-4 hundred each.. new from riso they are very expensive..
Jun 22, 2009 | Riso RZ220 Duplicator
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.IF I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
i am sorry to say that if this did solve the problem you will need replacement parts or a new drum
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Compatible 2 Packs - Risograph S568LA, S-568LA Master Rolls Logo
104 people viewed this question
Top Compatible Office Equipment & Supplies Experts
Ravi
Tom Chichester
Are you a Compatible Office Equipment and Supply Expert? Answer questions, earn points and help others
