Whats P98-25 error code on Riso RZ200 - Office Equipment & Supplies
    New Friend:
Hello to all I am M.traore Oumar technicians office in Ivory Coast I on looking for this map. riso RZ 200ep. error code P98-25
Posted on Nov 03, 2017
3 Suggested Answers
  • 81 Answers
SOURCE: I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
i am sorry to say that if this did solve the problem you will need replacement parts or a new drum
Posted on Jul 07, 2009
  • 22 Answers
SOURCE: RISO RZ200
D22-542 is saying that there's a problem with the printed circuit board on the print drum. It's not communicating with the machine. D04 -534 says that the incorrect ink cartridge is installed. First, is this a new drum you are introducing into the machine? if it is, not all drums are interchangeable. You need to get the right pcb (printed circuit board) for the ink drum you are using to match your machine. Second.. Something is mismatched here with the ink cartridges. The only way you'd get the ink cartridge error is if the drum is in the machine. I had this problem with a Rn 2130 ui.. I bought a used drum off e-bay and it wouldn't work. When I stole the pcb from another color drum it worked fine. If you have been using this drum in this machine before... be sure that the connection between the drum and the machine is good. Make sure you have the right ink cartridge too. Some of these aftermarked re-sellers sell stuff that doesn't line up with the tabs on the inside.. I've got some ink here that if you hold your toungue just right and turn the tube about 2 degrees it'l work.
Posted on Aug 14, 2009
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
How much would I pay for 2 x drums for a RZ200? Thanks
you can probably find them on ebay for about 3-4 hundred each.. new from riso they are very expensive..
Jun 22, 2009 | Riso RZ220 Duplicator
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.IF I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
go into test mode..
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
419 people viewed this question
jasbo
jasbo
