Question about Hartke Music
Blown fuse - Hartke Music
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
BEHRINGER K3000FX will not power on
It may be likely that you've blown a fuse. This will require removal of the amplifier unit from the housing. The fuse is a 100-120 V~: 6.3 A H 250 V. You should be able to find this in most places. If the fuse is not blown, then the unit must be sent in for servicing.
Feb 18, 2015 | Behringer Music
B115D
Hi, your amp has a short if the fuse is blown - it needs to be repaired - we can fix it - look on ebay. Thanks.
Mar 12, 2014 | Behringer Eurolive B115D Powered PA...
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Roland ac 60 sudden loss of power. Is it the fuse?
If you mean it's completely dead, no lights or anything, then probably the fuse is blown. The question then becomes"what caused the fuse tio blow?".
If however, by loss of power you mean it's quiter but still producing sound, then the fuse is not blown.
Sep 08, 2013 | Roland Ac60 Acoustic Chorus Guitar...
Peavey cs1000x amp fuse blown
Power amp transistors failure.
Jan 18, 2012 | Peavey Music
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I accidentally changed Dip switches and light has power but no fan and no light ..have I blown a fuse ..thanks
Not likely blown fuse. Verify the correct dip switch settings... SOMETIMES the switches don't quite move completely so make sure they are completely one way or the other.
Jun 17, 2011 | Chauvet Kinta 311X DMX DJ Color Lighting...
Good evenin' pluged a dx626 to 220V with all as it was from stock. it light for a moment and from that time doesnt work. problem in fuse? please help
It could have blown the fuse. The fuse is a part of where the power cord plugs in behind a little cover.
Most of the electronics is fairly well protected. If fuse is blown, replace with identical size and try it once. If it blows again, some parts in the power supply are damaged and will require service.
Apr 16, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have a Lowery Genie 44, with a blown fuse
Do not change the fuse without finding out why it is blowen. If the glass is black DO NOT even think of changing it or you will cause more damage.
I think if you take out the fuse you will find the raring under the end caps of the fuse.
Nov 02, 2009 | Music
Music Logo
60 people viewed this question
Top Hartke Music Experts
Electro Med Services...
dave nyman
Level 1 Expert
Tom Chichester
Are you a Hartke Music Expert? Answer questions, earn points and help others
