My netbook doesn't boot and shows remove media it uses an 8gb san disk can I install window 8 ? If yes how?
    Sergeant:
  • 324 Answers
Pls provide make and model of the netbook will be able to process accordingly
Posted on Oct 17, 2013
flipbooks
  • 177 Answers
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Posted on Jul 31, 2009
  • 11800 Answers
SOURCE: Asus Eee PC 2G Surf netbook fails to boot into OS
 Unfortunately Xandros is a paid (yes, you have read correctly , PAID) Linux distro. You will have to pay to get a Live-USB to reinstall.
Instead you should go here
http://www.pclinuxos.com/forum/index.php/topic,46097.0.html
  and follow the instructions to create your own PCLinuxOS (the one i use) Live-USB. You will need another pc for that. After booting from it all you're gonna have to do is to click on the Install icon on the desktop.
Posted on Dec 01, 2009
BearWeb
  • 357 Answers
SOURCE: Hello,
This means that your HDD is corrupted. This could have happened if your computer was dropped and sometimes it happens even when nothing has happened to it. If you take your computer to a repairman, he will be able to fix the HDD for you. Do not attempt to open the HDD yourself as the smallest piece of dust will ruin the HDD. The repairman will open it in a 100% dust proof room.
What might have happened is that the arm in your HDD has fallen on to the magnetic part of the HDD itself. Most of the data should be able to be recovered. If your laptop is only 8 months old, it should still be under warranty so i recommend that you take it to your suppler and they should fix it for free.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Posted on Feb 19, 2010
Vimal Dhiman
  • 147 Answers
SOURCE: boot error "Remove disk or other media"
First of all check your hard driver its working or not If its working then you there is problem with your operating system boot form your operating system cd rom and repair your operating system.
Posted on Jun 07, 2012
  • 6771 Answers
SOURCE: boot error "Remove disks or other media"
Set the hard drive to boot first, I find this fixes most boot errors.
Posted on Jun 08, 2012
Can I install windows 8 on a netbook with a 8gb san disk
yes you can. use "windows download tools" to set up usb installation drive first. then you can boot from the usb drive to install windows 8, as long as your hard drive is having at least 30gb free spaces.
clean install is recommended.
Oct 16, 2013 | Computers & Internet
2002 cad. sls sev. r&r starter around the intake
You will need an Ubuntu Live boot CD, you can download from ubuntu's site. Burn to disc and Boot to it on your laptop.
  • Once booted, select Try Ubuntu without installing.
  • Open a terminal (ctrl + alt + t)
  • type sudo fdisk -l
  • This will show all your partitions, your main part should be the biggest usually sda1
  • Type sudo mkdir /media/sda1
  • Type sudo mount /dev/sda1 /media/sda1
  • Now Type sudo chroot /media/sda1 to change to your disks context
  • Now enter passwd <username> where <username is your login name, remember it is case sensitive.
  • Now enter a new password twice.
  • Now remove the ubuntu disc and reboot. Your password should now be the new one you created.
Dec 18, 2012 | Acer Aspire One AO532H-2527 Netbook
I have a gateway netbook that i can not get to set up
Do a cold-start , unplug, remove battery, leave battery out during this process, plug in , push on/off button, and repeat the process.Remove any media, USBs, DVD/CDs, Cables, etc. Are you offered, in restore, different "Dates" to restore? If so choose another date to restore to. You may have to load the recovery partition, if all else fails. You could load a USB with your windows version repair disk, you didn't supply info, and at boot go to Boot Menu and direct the machine to load from the USB.
Nov 17, 2012 | Computers & Internet
Reboot and select proper boot device, pxe e61 media test failure check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 04, 2012 | MSI L1350D-1672US Netbook
How to install wins 8 on dell Inspiron netbook 1018
proceed according. God bless you
  1. Create a New Partition
    • 1 Launch the Disk Management tool on your computer running Windows 7 by opening the Start menu and typing "diskmgmt.msc" in the search bar. The Disk Management tool, showing all connected storage devices, appears.
    • 2 Pick the hard drive onto which you'll install Windows 8. The normal choice is Disk0, which is the primary hard drive. This disk should already show your C: drive, and possibly other items like recovery partitions.
    • 3 Verify the available free space on the selected disk. For most computers with no other dual-boot setups installed, the entire drive should be occupied, so you'll have to shrink an existing drive (like C:). If there is a section with a black bar titled "unallocated," then this represents free space not currently in use.
    • 4 Shrink your C: drive by right-clicking on it and selecting "Shrink Volume." The computer assesses and reports how much free space is available on the disk. You need a minimum of 16GB of free space to install 32-bit Windows 8 and 20GB of space for 64-bit Windows 8. Type either 160000 or 200000 in the "Enter the amount of space to shrink in MB" box. Increase that number if you want additional storage space for files and programs within Windows 8. Click "Shrink" to continue.
    • 5 Right-click on the new unallocated space and select "New Simple Volume." Leave the defaults, ensuring that NTFS is selected as the file system type. Give the drive a name, like "Windows 8."
    • 6 Insert your Windows 8 installation disc or USB drive into your computer. When the new drive is formatted, restart the computer and boot from your installation disc or drive.
    Install Windows 8
    • 7 Select "Custom" during the Windows 8 Setup initialization process.
    • 8 Select the new drive you created when the installation program asks you where you want to install Windows 8. Be sure to select the drive with the label you used for the new drive; if you install to the C: drive, you will overwrite your existing Windows 7 installation.
    • 9 Follow onscreen instructions to install Windows 8.
    • 10 Reboot after you install Windows 8, ensuring that you've removed any installation media. When the computer restarts, you are presented with a boot screen that lets you pick between Windows 7 and Windows 8.
Oct 18, 2012 | Computers & Internet
My acer aspire one netbook AOD257 keeps telling me no bootable device insert boot disk
Oct 17, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hi my son was on website and hes net book crashed so he turned it off.when he put it back on it says windows/system32/config/systems and to prees r to fix but it does nothing.can this be fixed
yes, you need a windows installation disk, but in your case a netbook doesn't have a cd drive so you need to convert the disk to a bootable usb you can do this here http://wintoflash.com/home/en/
To repair windows you can follow the following link:
http://www.geekstogo.com/forum/topic/138-how-to-repair-windows-xp/
I hope this helps, it's a bit complicated, I might suggest taking it to the nearest repair shop.
Apr 19, 2011 | MSI Computers & Internet
How to format 8 gig scan disk for mp3
How to format the Sansa View:
To format the player directly, follow these steps:
1. Select More from the Main Menu.
2. Select Settings/Options then System Settings.
3. Scroll down to Format and select it.
4. Select Yes to start formatting.
WARNING: Formatting the player will DELETE all the content you have
on the player.
The player can also be formatted using Windows Explorer or Windows
Media Player.
Dec 25, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Dec 01, 2009 | ASUS Eee PC 2G Surf Notebook
Need to know how to upgrade a hard drive from a 8 gig to 80 gig
I am typing this on a Dell 4600 RIght now. You need to look up how to set the jumpers on the internal hard disk ( 8GB) to SLAVE MODE, and set the 80GB to Master.
Remove the 8GB from the metal bracket, and put the 80GB in its place. Put the 8GB beside it. Plug the 80GB into the end of the IDE cable, and the 8GB into the middle. When you boot, you can hit F2 to go into the bios, and change the boot order from HD0 to HD1 and you can boot from your 8GB.
Now, If you want to boot from the 80GB, ( which I would ) you need an operating system.
Get your Disk labeled Reinstallation CD, Microsoft Windows XP Home Edition, Including Service Pack 1, and boot from it. Then format the 80GB, and install the OS There.. You will need your WIndows XP Home Key. ( you can either get it off the case or use Magic Jelly Bean Key finder to get it off your 8GB. Get the key and write it down. ITS IMPORTANT ).
Then you can change your boot order in BIOS, back to HD0, and boot from your fresh copy of XP Home.
If your interested in having a close to seamless experence as possible, you might want to invest in a copy of Partition Magic Pro. It can copy both the restore partition, ( the first 600MB of your 8gb disk ) and the primary partition of the 8gb, and resize the 8gbs primary partion on the 80gb to 80gb. ( YEA! ).
If you have *any* *any* lack of understanding please clarify
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
