Question about Dell Wyse Technology Wyse Z Class Horizontal Foot Kit
Wyse z907d factory reset
How to reset this wyse box to factory reset. i have tried g reset and it is not working.
How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Oct 03, 2012 | WYSE Winterm 1125SE Network Terminal
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
How do you reset factory settings for a Wyse V10L? We tried holding down G and it will not go into reset settings. Thanks!
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
Jan 20, 2011 | WYSE Computers & Internet
Wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error....
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
Dell Wyse Technology Wyse Z Class Horizontal Foot Kit Logo
41 people viewed this question
Top Dell Wyse Technology Computers & Internet Experts
David Payne
David Payne
Are you a Dell Wyse Technology Computer and Internet Expert? Answer questions, earn points and help others
