Question about ASUS Computers & Internet
Eject usb device freezes system
When ever is disconnect a usb3 device the system freezes. I have to turn it of manually.
    Sergeant:
  • 324 Answers
Uninstall the USB drivers from device manager and reboot pc and then re install - should fix the issue - also go to safely remove devices option before disconnecting the device
Posted on Oct 17, 2013
How do i fix my usb slow data transfer speed
Make sure that JUSBV1: Power Source Header for USB Ports Pin 1-2 Close: +5V for USB ports at JUSB2/JRJ45USB1 If the jumper is on 2-3 the standyby section may not be providing enough current, thus causing the problem. With some USB devices this problem of high current demand is so severe that a USB3 add in card has to be put into the system to meet the current demand. The USB3 cards have a receptacle on the rear of the card where one of the power supply Molex cables is plugged in. This ensures adequate current and voltage. USB3 can provide 1.5 Amp, USB2 only 1 Amp.
Jul 22, 2015 | Biostar G31D-M7 Motherboard
Is the dell inspiron 580 a usb 2.0 or 3.0
I don't think your computer has USB3, because USB3 came after 2009. But that should not stop you from buying an USB3 hard drive. My computer did not have USB3, and I used USB3 drives, long before a bought a USB3 extension card. You always van connect an USB3 drive to an USB2 computer connector. Ans an USB2 drive to an USB3 computer connector. The slowest part in the chain, will dictate the maximum speed. But even with the USB3 drive, now on your computer, the computer can't use the full speed, but if you buy a new computer, the same drive can be used on a much higher speed.
I did put in a USB3 extension card, but it did not help much. My internal computer buss is slowing things down, so even my USB3 drives, most of the time only reach 35 Mbyte/ second. A speed USB2 could reach too. But connecting my drives to newer computers makes them almost 3 times as fast. And with the file sizes I'm sometimes have to put over, that really makes a difference.
Oct 30, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Dell e6440 usb 3.0 port not working
Does the usb3 socket recognize usb1 or 2 equipment?
I have usb3 but is will not run at 3 speed without the usb3 cable and usb3 device. The cable has a, what looks like, a squashed HDMI plug.
There should be usb3 hub loaded in your device manager.
Download the drivers from dell and see if that fixes it. All drivers are free of charge.
Mar 22, 2014 | Dell LATITUDE Computers & Internet
Problem with mouse usb
It sounds to me like your USB mouse is not USB2 compatible. Use it while it is connected to the USB3 port. Did it at one time work in the USB2 port?
Mar 19, 2014 | Computers & Internet
How can I have a hi-speed USB host controller for USB Mass Storage Device that my compaq E500 needs for maximum performance ?
Your computer supports USB1, it is highly unlikely there is a BIOS upgrade for high speed USB2 and USB3 support.
The only alternative is to install an USB 3 PCI card into your computer's PCI expansion slot.
Check out these cards from this WEB site.
http://www.comparend.net/usb3-cards-pci?i=cau_cmrd_1_24046~5337154074
Mar 04, 2013 | Computers & Internet
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Dec 13, 2012 | Computers & Internet
Seagate FreeAgent 500gb disk removed warning and disk ejects and reconnects during backup
it might not have enough usb input you might need to have a usb3 card installed
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Oct 15, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
Msi gx660r usb
Sorry, I'm not entirely sure by what you mean by "falls over", but I guess devices fail when plugged into it.
Does it fail on just the USB3 ports, or both USB2 and 3?
what sort of devices are you using - low power devices such as mice, or higher power devices like 2.5" USB hard disk enclosures?
To be honest, I'm not familiar with USB3.0... but I assume you will need a driver to run them... perhaps downloading and installing the driver from msi may fix the issue, if its a driver corruption issue?
If it fails with any device in both USB2 and USB3 ports, the cheapest and easiest workaround may be to buy a Expresscard USB card.
Hope this info helps.
May 19, 2012 | MSI GX660R-060US PC Notebook
I am trying to connect leapfrog leapstar to computer and follow application but when I connect usb with computer the leapstar says Please click "Eject button" Where is the eject button? I've...
The Eject button appears when a Leapster2 handheld is connected and turned on. When you have finished configuring the Leapster2 handheld and your child wants to play with it, you can click the Eject button to disconnect the device. Once ejected, a message will appear letting you know that it is safe to disconnect the Leapster2 handheld from the computer. It is not really a "button" but a picture of a green button which says "EJECT". It should be located on the upper right corner of your screen.
Sep 20, 2011 | LeapFrog Leapster 2 Learning System
I have an Msi K9VGM-V mainboard and I bought an Msi Star USB 3.0 expansion card. The USB card speed isn't enough fast. The card speed only so fast as USB 2.0 slot( 20-30 Mb/s). I didn't find...
The driver
http://www.msi.com/service/download/driver-12322.html
BTW the speed is determined by the speed of the device plugged in, the card will run at its speed, not the other way around.
Aug 10, 2011 | MSI K9VGM-V Motherboard
Computers & Internet Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
