Question about Maestro Electrical Supplies
My maestro infrared dimmer is stuck at a midpoint or low point and I can't get it to completely light up without double tapping it. How can I fix that? I went online to their webpage and followed the instructions but it doesn't seem to work.
badenhop
  • 44 Answers
SOURCE: A fixture on a Lutron Maestro dimmer switch stopped working.
This dimmer was not made to dim a load smaller than 40VA. That halogen bulb would only have been 20VA or so.
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
I think that when your bulb burnt out, the dimmer over-volted the transformer and smoked it. That said, I think you have a fixture problem and, possibly, a switch problem, too.
Posted on May 30, 2009
VtToolMan
  • 704 Answers
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Posted on Sep 10, 2009
  • 323 Answers
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Posted on Oct 31, 2009
  • 66 Answers
SOURCE: lutron maestro IR remote control wireless dimmer won't work
http://www.lutron.com/wallboxvideos/maestro_ir_remote_programming.html
If you have followed the programming instructions, the only thing that might be wrong would be the power wire and switch leg wire may be installed on the wrong screws on the back of the device. Be sure that the wire bringing power "INTO" the box is connected to the "Black" screw on the dimmer and the wire going "OUT" to the light fixture is on the "Gold" or "Brass" colored. If these are backwards the dimmer will probably work, but the IR would not. If you are positive it's wired correctly and the IR remote still won't sync up, call the 800 number at the end of the attached video for Lutron Technical Support. Good Luck!
Posted on Nov 12, 2009
  • 152 Answers
SOURCE: Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Posted on Dec 06, 2009
I have an older Lutron system - the Maestro Wireless MRF-VCTX-WH. I can't find instructions to reconnect one dimmer. The only instructions online that I can find are for the Pico, and that process doesn't...
Hard a hard time finding it too. Found an old instruction sheet lying around:
Step 1) Turn the Dimmer On
Step 2a) Press & hold the Dimmer's tap button. LEDs will blink one at a time, from the bottom up to the top. After approximately 8-seconds, the LEDs will start to cylce slowly from top to bottom (setup mode). CONTINUE to hold the tap button and go to step 2b.
Step 2b) Press and hold the "ON" button on the Wireless Controller (MRF-VCTX).
Step 2c) Once the dimmer learns the wireless controller, the LEDs on the dimmer will cycle quickly from top to bottom. Release the dimmer's tap button to exit set-up mode, and release the wireless controller's on button.
Repeat steps 1-2c for each additional dimmer.
Apr 24, 2011 | Lutron MRF-VCTX-WH Maestro Wireless White...
I replaced a standard single pole light switch with a lutron Meastro dimmer switch with remote. It does not work. I replaced the standard switch and all was good. This circuit is on the same line a gfci...
Hello. There could be a couple of possibilities. First is the simplest to verify, is it a Companion Dimmer, Standard Dimmer switches or a 600W or 1000W Maestro Wireless Multi-location Dimmer. The Maestro Companion Dimmers can not be used individually, as they do not control a load, and must be used along with a Maestro or Maestro Wireless Multi-location Dimmer. The Campanion Dimmers are also a line/low voltage rating, and rated for incandescent and halogen but may not handle some flourescent fixtures. The other thing I can think of is that you may have interfearence from another item. They are radio frequency (RF) devices that communicate together for wireless control of lights. Here's two links that may be of some help, the second has downloadable install instructions.
http://www.smarthome.com/6601LA/Lutron-MA-R-LA-Maestro-Companion-Dimmer-Switch-Light-Almond/p.aspx
http://www.prolighting.com/lumamaprsmre.html
Hope this helps out, don't forget to rate this answer.
Thank You,
Richard
Mar 14, 2011 | Lutron SCR-20-GFCI - Dimmer Controls -...
I have always used a lutron maestro dimmer. I replaced the chandelier and put in 6-60 watt bulbs. My previous chandelier used 18-25 watt chandelier bulbs and the dimmer worked fine. after changing the...
You should have just two wires plus a ground hooked up to the dimmer. It should install just like the maestro. If you are getting no lights with a double tap, or tap and hold, and if the led is not on, it is one of several things. Most are basic, but will list anyway. Check that your connections are good. Make sure you have power there. Make sure the bulbs are good. If all is fine, you probably have a defective dimmer if it worked prior to this. To test, take the dimmer out, restore power, and carefully touch one insulated wire to the other one. If the light comes on, it is the dimmer at fault.
Mar 06, 2011 | Lutron ELECTRONICS MAW-600H-LA SMART...
The LED indicators on my Lutron Maestro continuously run up and down without stopping and the lights (or fan) will not work? It seems as if the entire switch is frozen... Whats the problem?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which apparently excludes CFLs.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Maestro Lutron Ir Dimmer Mir-lfqthw...
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1-800-523-9466
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I have installed the Maestro dimmers with the recommended CFL dimmable bulb but when i turn on the power the dimmer cycles up and down and dosent stay on. i have installed one incandescent light in a room...
Maestro dimmers are not recommended with any CFL for pretty much the reasons you are experiencing. The electronics within the CFLs are probably not letting the power circuitry in the Maestro charge-up - and because of that, it comes as no surprise that adding an incandescent lamp solves the problem. The company makes products that are compatible in their Ariadnia/Toggler & Diva product families, but not Maestro - you just need to make sure the dimmer itself identifies itself as compatible with CFLs.
Dec 20, 2010 | Maestro Electrical Supplies
Rocker switch works, FASS OK also, but tap switch is broken. can I fix it or does it have to be replaced?
The electrical devices that fit into a wall box are not repairable. This is true for dimmers, switches timers and receptacles.
Oct 23, 2010 | Maestro Lutron Dimmer 1000 Watts...
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
LUTRON DIMMER
Feb 10, 2009 | Lutron Electronic Low-Voltage...
Electrical Supplies Logo
Top Maestro Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
