Question about HP DeskJet 3940 InkJet Photo Printer
My printer doesn't work
When I want to print a document I get the message "user intervention required". How do I fix this, I need to use my printer, HELP
Didn't work in my printer ,pls give drive cd.my e-mail ID
sam007king@yahoo.co.in
Posted on Apr 11, 2008
How can I fix the issue when my printer says "User intervention required?"
I'd guess you have a paper jam, maybe even tiny piece.
Check error message on printer's panel. try turn off for 10min.
turn back on. Users manual on software install CD may help understand message.
Mar 08, 2015 | HP Office Equipment & Supplies
My printer can not work because at display print queue there are warning "user intervention required", I has been trying with reset manual and sofware (Ip tool) but did not still working. so...
my printer can not work because at display print queue there are warning "user intervention required", I has been trying with reset manual and sofware (Ip tool) but did not still working.
so what the best solution for fix it ?
Jul 07, 2011 | Canon PIXMA iP1300 Printer
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I unistall drivers and install it again it works but whenever I restart the...
This is a firmware bug that was resolved after ver 4.13, you may need to contact epson support to request a copy or upgrade as it is not downloadable through standard sources
May 11, 2011 | Epson TM-U220PD Matrix Printer
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
install the driver n check by replacing the u.s.b cable n switching it on different ports
Aug 04, 2009 | Sharp AR-5320 Black and White Copier
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
User Intervention Required Message Epson TMU375 receipt printer
Got to start/settings/printers and faxes .saelect epson 220 printer go to properties and select ports.Change ESDLPT1 port to lpt1 port and uncheck enable bi directional option .Apply and o.k.printer will work fine
Dec 30, 2008 | Epson TM-U220 Matrix Printer
http://h20000.www2.hp.com/bizsupport/Tec...
The link above may help you. It applies to HP printers,but
might solve your problem with your Canon printer.
Jun 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
LEXMARK Z13
Hi go into the printer folder and check that the printer states ready not offline if it does state offline right hand click on the icon and select use printer online. If this still doesn't fix the problem then double click on the printer icon this should open the printer window where you will be able to see what is and been sent to the printer.
Click on the document heading and select restart. This should restart the printing with no problems but if it doesn't then click on the Printer heading and select cancel all documents then try printing again.
Hope this helps you
Thanks J
Nov 21, 2007 | Lexmark JetPrinter Color Z13 InkJet
HP DeskJet 3940 InkJet Photo Printer Logo
600 people viewed this question
Clive
Clive
