Question about JVC KW-XR810 Car CD/ MP3 Player
I reset my jvc xr810 with a paper clip and now it wont turn on
How do you reset the jvc kd-s79bt?
Under the facia plate should be a reset button, use a paper clip or similar to press it in or disconnect the battery for a couple of minutes!
May 22, 2015 | JVC Car Audio & Video
JVC CAR STEREO DECK MODEL NUMBER KW-XR810 ONE WEEK AFTER INSTALLTION OFF KENWOOD AMP DECK STARTED SKIPPING AROUND ON THE PRESET CHANLES AND.THIN THE CD IN THE DECK STARTED PLAYING NOW THE CD IS STUCK IN...
It sounds like you may have a stuck or bad switch. Try checking to see if any of the buttons are jammed. If they all seem fine, you will need to check the switches with a multimeter set to check resistance.
Dec 30, 2014 | Car Audio & Video
JVC KD-G801 CD player has light on (on) button but doesnt switch on when pressed
Look for a pinhole button on the face, just left of the #1 radio preset. Use a ball point pen or paper clip to lightly hold this button for 2-3 seconds. You may do this with the key on. This will reset the radio's microprocessor.
Let me know if this helps.
Dec 18, 2013 | JVC KD-G801 CD Player
JVC KW-xr810 source changes by itself/randomely. IS it a swc problem with my Tacoma?
I would suggest you install a 12 Volt power filter to the device in question, this will filter out any spurious electrical noise that may be triggering this problem, These filters are available on line and any auto sound supply store or center.
Jan 15, 2012 | JVC KW-XR810 Car CD/ MP3 Player
My jvc truck stereo on displays 000=a what does tht mean
I just had the same problem with my JVC stereo, removed the face held the reset in with a paper clip for 10 secs put the face back and its working fine now
Note: doing this you will loose all your preset settings
Apr 16, 2011 | JVC Car Audio & Video
Will not turn on but have green light
Try resetting it by inserting a small pin or paper clip through the reset hole ( look underneath the tomtom ). if it wont reset then it's likely 2 IC's have blown inside ... U24 and U25.
Aug 21, 2008 | Tomtom GO 300 GPS Receiver
How do i reset it.? i charged it on the computer fully now it wont turn on please help
Yes you can reset it but i have the same problem. To reset you need a paper clip. Insert the tip of the clip into the small hole beside the head phone jack and gently push.thats it.Good luck.
Jul 04, 2008 | Dell DJ Ditty MP3 Player
JVC KW-XR810 Car CD/ MP3 Player Logo
145 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
