Question about Danby Premiere 12,000 Btu Portable Air Conditioner With Dehumidifier Dpac12011bl
Display says stop - Danby Premiere 12,000 Btu Portable Air Conditioner With Dehumidifier Dpac12011bl
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
My dehumidifier stopped working and the display is showing dashes where the numbers should be??
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 03, 2011 | LG LHD45EL Dehumidifier
It stopped working. One display reads "CH" and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Mar 26, 2011 | Comfort-Aire BHD-501 Dehumidifier
Our LG LHD45EL dehumidifier stopped working. The bucket full light flashes, though the bucket is empty and the filters clean. The display shows CH01. The manual does not say what CH01 means. Any...
I don't know what CHO1 is either! My husband and I had the same problem a couple years ago. We just ended up buying a new one.
http://www.donmurraysbobcatandtipperhire.com.au
Jul 22, 2010 | LG LHD45EL Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
1: 42 25805 DEHUM 50 PT ELEC w/PUMP Lost manual - how do we set the timer to shut off at night?
How to program the delayed start function: From the OFF Position.
1) With the unit OFF press the clock/timer button and use the and - buttons to set the number of hours after which the appliance should start functioning.
How to program the delayed stop function: From the ON Position
1) Press the clock/timer button and use the and - button to set the number of hours after which the appliance should stop functioning.
2) Ont the left side the display will show the number of hours to start/stop and the dot under the clock/timer symbol indicates that the timer has been selected.
Jun 13, 2010 | Kenmore Dehumidifiers
Dehumidifier stopped working
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 18, 2010 | Fedders A7DH65B2A Dehumidifier
Danby Premiere 12,000 Btu Portable Air Conditioner With Dehumidifier Dpac12011bl Logo
29 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
