Question about Performance Teknique ICBM-780 Digital Monoblock Amplifier Daisy Chain Capable (1600W Max) Car Audio Amplifier
Wont work Hooked up amp, lights up, but no sound. Was blowing inline fuse, installed a bigger one. Now no fuses are blowing but I still can't get any sound. What could it be?
    Problem Solver:
  • 6 Answers
If you were blowing an inline fuse, what size was the fuse and how big did you go up? It's possible the has a short in it.
Posted on Oct 01, 2007
SOURCE:
Why does my 20 amp fuse blow when the engine is running, but work without issue when the engine is off?
Why fuses blow or how to find short circuits or drains !
fixkick.com/power-elect/blows-fuse.html
(the Park (tail-running) lamps go to up to 20+ places) ... The below covers shorts in the cab box, not the 50-100 amp engine bay fuse box that loves to rust out.
Nov 02, 2015 | 2013 RAM - 1500
I put brand new 50 amp fuses in and everyone I've put in keeps blowing also the tail light doesn't work either on the driverside
FIRST of all you check all the items on the fuse that blows then remove all the fuses or wires to that item,i dident think the tail lights were 50 amp but still remove the plug from the rear lights and trace them to wards the front ,it sounds like a wire harness is trapped and shorten out about where the door shuts .where the tail gate closes.something under the floor .or under the body on chassis,but when you check all that works like nothing on the left of cab then thats where you start looking .or a wire hanging on the side of the engine ,but dont put in any more fuses untill you have checked out all possible wires either trapped or not .
Keep looking and you will find it AND only use the amp fuses the book says nothing bigger as a dead short wont only blow it can cause a FIRE.
lET ME KNOW HOW YOU GET ON it will take you a few hrs ....goodluck.
Ron
Jan 02, 2011 | 2007 GMC Sierra 2500HD
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
Automotive wire in line fuse keep blowing fuses
sounds like eithor over draw or short
yes you can over draw the wires
Dec 21, 2009 | LG Art Cool LA1000PR Air Conditioner
Fuses keep blowing
if the inline fuse is blowing, you are putting out more power than what is getting to it, thus overloading the fuse and blowing it. Try a bigger fuse first and if that doesn't work, you will need to get a larger guage power cable with the bigger fuse. Also check your ground is properly grounded.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 08, 2009 | AudioBahn A2150HCT Car Audio Amplifier
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp blows the fuse every time.
it aint the wire, the bigger the better.
try checking your ground, if there any rust clean with sandpaper. if your gain and freq is cranked it will blow fuses and cut out, cuz the protect mode kicks in
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Green light turns red on hard notes with kicker 750 mono amp
First off, never, ever replace a blown fuse with a bigger one (especially one that is almost twice as big) unless it's an absolute emergency. Most of the time, the reason a fuse blows is because of a problem with the device (in this case, the amp). By installing a larger fuse, there's a very good chance the problem will become permanent (i.e. busted amp).
The amp could be going into an overcurrent mode when the bass hits and power cycling itself to try and reset the problem. If this is the case, take it to a local electronics repair shop and see what they can do.
It's also possible the input voltage to the amp is dropping too low during the bass hit, making the amp restart. Try putting a 1.0F or higher capacitor on the battery to buffer the power during the bass hits.
Mar 16, 2009 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
123 people viewed this question
Top Performance Teknique Car Audio & Video Experts
Mike Duncan
Mike Duncan
Pierre Laplante
Jay Plesset
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
