Question about Broan HRV200H Heat Recovery Ventilator 108 235 CFM
I need to replace the motor for brown HRV200H
Replacement motor
Did you check out ebay? Google it.
Mar 02, 2016 | Oreck XL Professional Air Purifier
Honeywell power supply F50A1017 not working
could be the switching board switch they fail over time capacitors you can tell by looking at them in most cases, diodes bit more harder but if there is any black or brown marks round them then theses can be faulty.. but if there is any yellow/brown colour round the capasitoes then they will have gone.
Mar 16, 2014 | Honeywell (F50F1032) Air Purifier
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
Electric motor makes screeching sound and stops running.
The motor has worn bushings making the motor shaft hot and swell and eventually seize. You can let it cool off and it will more than likely run again until it heats up again. The motor will have to be replaced if you want to repair it.
Jun 05, 2011 | Honeywell Enviracaire 12520 Air Purifier
The motor makes a squeeking sound, like the bearings are gone. Can I replace them or is it easy to replace the motor?
The motor has bushings that need to be oiled once every month or two. If you e-mail to miller@healthyti.com they have supplementary cleaning instructions available to email back to you. Those instructions include oiling instructions.
Dec 10, 2009 | Ecoquest Flair Air Purifier
Unit hums slightly but fan doesn't turn. I cleaned dust out of unit but still no results.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 06, 2009 | Ecoquest Flair Air Purifier
Broan HRV200H Heat Recovery Ventilator 108 235 CFM Logo
61 people viewed this question
Top Broan Air Purifiers Experts
Are you a Broan Air Purifier Expert? Answer questions, earn points and help others
