Question about Rugged Notebooks General Dynamics Itronix GoBook VR-2 Notebook
Reset battery jumper join - Rugged Notebooks General Dynamics Itronix GoBook VR-2 Notebook
I have dell CPX H500GT and lost BIOS password
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
hope this helps
Feb 27, 2011 | Computers & Internet
Sirs I have not made any password for entering bios setup for compaq presario x1370 us, but when try to enter bios setup by pressing F10, display for administrtor password appears. What password could i...
But there is no need to worry. There are many known ways to reset / remove / bypass the password: Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. If it fails, then try to remove the battery for at least one hour. B. By Using the Motherboard Jumper: Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin. Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Feb 25, 2011 | Compaq Presario X1370 Series Laptop...
Forgot the password and cannot start my laptop
Hope this helps
hope this helps
Jan 25, 2011 | Computers & Internet
Need to change mouse settings on bios but i forgot my password
Jan 24, 2011 | ASUS M51Ta-X1 NoteBook
I need to Reset bios
Hope this helps
Dec 29, 2010 | Toshiba Tecra A2 Notebook
How to reset your bios on a C1110
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Do it at your own risk or under any technical guidance.
Mar 12, 2010 | Fujitsu Siemens LifeBook C1110 Notebook
How do you reset or bypass cmos password on msi wind u100 notebook.
hi this is kamal..
pls follow these steps:
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
best regards
kamal singh
Oct 09, 2009 | Computers & Internet
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Oct 08, 2009 | HP Compaq 8510p Notebook
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
Remove bios password
There are lots of tools/software available to reset bios password. Just google for "reset bios password" and you will find one of them, else just open your back side of your notebook. Open the screws and remove the bios battery (a circular shaped sitll battery). If possible change the battery with a new one or keep that battery out of laptop for some time. Now start notebook without the battery and shut down.Then reinsert the battery to laptop and start again. The password should be resetted by this process.
Feb 17, 2008 | Computers & Internet
Rugged Notebooks General Dynamics Itronix GoBook VR-2 Notebook Logo
Top Rugged Notebooks Computers & Internet Experts
David Payne
David Payne
Are you a Rugged Notebooks Computer and Internet Expert? Answer questions, earn points and help others
