Question about Tornado Tools 21.6V Cordless Drill Kit
Where do I get a replacement battery for my Tornado 21.6 v drill
Posted yesterday. I am looking for a replacement battery for my Tornado Cordless Leaf Blower
There should be a model number on the battery itself. From there you can contact Batteries Plus and they should be able to get you a replacement.
Jan 17, 2015 | Tornado Cordless Leaf Blower
How do I get a replacement battery for a Tornado cordless leaf blower?
The Internet lists many domestic and foreign battery suppliers. First, remove the battery housing to see what kind of battery is in the unit. Several replacement types can also be found at a battery store like Batteries Plus. If you are not ready to do it yourself, the guys there can rebuild the battery pack for you .... for a price. Often you can do it yourself if you have any soldering skills and the tools to do it. Expect to pay about 3/4 the price of a new 'off the shelf' battery direct from the manufacturer if they do it all, and 1/2 the price for just the new battery cells and you do the work. Hope this helps.
Jan 15, 2015 | Tornado Garden
Can't engage drill or hammer settings on de walt dc 925 xrp
Try turning the ring to 2 or 3 and run the drill holding the chuck so the clutch slips then try turning it to drill setting. Also try to do it in different speed settings. If not it sounds like a fault in the gear module. It might just be a metal clip just under the clip in side. Undo the 4 screws holding the gearbox onto the housing and carefully remove it, you might see the fault or loads of dirt that needs cleaning. Go to http://www.2helpu.com/world/map.aspx for a drawing.
Jun 01, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
4270-21 Compact Magnetic Drill Press: mag base will not hold at all...
If I'm not mistaken, these drills use an electromagnet. Start by measuring the current when the magnet is switched on, but not the drill. If you don't have a current meter, just plug the drill plus an incandescent light into a long lightweight extension cord. You should see the light dim a little when you switch on the magnet. If the light doesn't dim, you just aren't getting power to the electromagnet, and it's probably a broken wire or a bad switch. If the tool has it's own fuse, I would think it would be for the drill only, not the electromagnet.
May 06, 2010 | Milwaukee 4270-21 Compact Magnetic Drill...
What is the output of the charger for the B&D cordless drill 9049a?
The output power will be higher the the battery itself, a 14.4V will be up around 16-18 Vdc. an 18 V will be 20-21 Vdc. Now this is if your testing it with a multi meter and it is not under a load.
Dec 14, 2009 | Black & Decker Drills
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
How to change the battery 2004 Benelli 900 Tornado TREon a
Hi Wlvanness, I am sorry you can't find the first and best tool you ever bought for your Benelli but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to Change Motorcycle Battery
Important trick to installing motorcycle battery
https://dl.dropboxusercontent.com/u/35177464/Benelli/TornadoWiringDiag.pdf
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/Tornado%20workshop%20Manual.pdf
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/TORNADO%20User%20Guide.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 20, 2009 | 2004 Benelli Tornado Tre 900
Tornado Tools 21.6V Cordless Drill Kit Logo
102 people viewed this question
Top Tornado Drills Experts
Tom Chichester
Are you a Tornado Drill Expert? Answer questions, earn points and help others
