Question about Texas Instruments BA-II Plus Calculator
How to solve 2^3 - Texas Instruments BA-II Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the y^x key just above the 9 key. Press 2 y^x 3 =
Posted on Jun 01, 2014
How do I sole system of equations
To solve a system of equations, there are two algebraic ways to solve them, one is by substitution, while the other is elimination.
1) 2a + 3b + 5 = 0
2) 2a + 4b + 10 = 0
-b -5 = 0 (subtract 2 from 1)
+b-b-5 = b
-5 = b
Substitute into 1) to solve for a.
2a + 3(-5) + 5 = 0
2a -15 + 5 = 0
2a -10 = 0
2a -10 + 10 = 10
2a = 10
2 2
a=5
Substitute into 2) to check if we did it correctly.
2(5) + 4(-5) + 10 = 0
10 -20 + 10 = 0
0=0
Good luck.
Paul
Feb 10, 2015 | Office Equipment & Supplies
Solve the following equation for a. a^2 + b^2 c^2
There is nothing to solve here.You just have an expression with two letters; you have no equation to solve because you need an = sign.
Sep 07, 2013 | Office Equipment & Supplies
Solve(x^2=21)
Syntax should be solve(x^2=121,x) ENTER or solve(x^2-121=0,x). Solutions are x=-11 or x=11.
Jan 05, 2012 | Texas Instruments TI-89 Calculator
2x^3+6x^2-x=3 I know -3 works for x. But so does -or+ square root of 2 divided by 2. I need the steps so I can see how you get -or+ square root of 2 divided by 2. The question says solve for x.
On most calculators with a solver function, you can specify a starting value for the variable (in this case x) after pressing [Solve] but before pressing the = key.
To get the three solutions, try entering the function, pressing [Solve] then an estimated starting point (say 0.5 or 0.7) then [=]. This should show the +root2/2 result (ie 0.7071067812).
You should not need to enter the function again.
Follow this by pressing [Solve] again, then another estimated starting point (say -0.5 or -0.7) then [=] to get the -root2/2 result.
Similarly, then press [Solve] again, and enter another estimated starting point (say -2) then [=] to get the final solution of -3.
On Casio calculators, the [Solve] function is usually found by pressing [Shift][Calc]. Note that the solver function generally won't return numbers in surd form, only as a decimal value.
Jul 07, 2011 | Office Equipment & Supplies
I want to know how to solve the Cubic equation on TI-89 Calculator
There are a lot of ways to do it. One is to write a program using the cubic formula. If you just want the roots, use the solve() or zeros() functions.
For example, to find the zeros of x^2-6x^2+11x-6, enter
solve(x^3-6*x^2+11*x-6=0,x)
or
zeros(x^3-6*x^2+11*x-6,x)
Note that solve() has "=0" in it while zeros() does not.
solve() will give you an answer of
x=1 or x=2 or x=3
while zeros will give you an answer of
{1 2 3}
which plainly are the same thing, just expressed differently.
May 09, 2011 | Texas Instruments TI-89 Calculator
How do i solve the equation x2-13x+36=0
Use the quadratic formula or completing the square.
Completing the square:
x^2 -13x=-36
x^2-2*(13/2) +(13/2)^2=-36+(13/2)^2
The left side can be factored as (x-13/2)^2.
The right side is (13^2-36*4)/4=(169-144)/4=25/4
Assembling the two sides
(x-13/2)^2=25/4
Taking the square roots x-13/2=+ or - 5/2
Case 1 : x-13/2=+ 5/2.
Solving for x you get the first root as x=(5+13)/2=18/2=9
Case 2 : x-13/2=-5/2.
Solving for x, you get the other root as x=(13-5)/2=8/2=4.
The roots are x1=9, and x2=4
Apr 20, 2011 | Casio FX-115ES Scientific Calculator
How do I solve x and y in the following equations? 5x+3y=6 2x-4y=5 Thank you
You can solve it with following method.
5x+3y=6 2x-4y=5
So 5x=6-3y so 2[(6-3y)/5]-4y=5
So x=(6-3y)/5 so 12-6y-20y=25
so -26y=25-12
so -26y=13
so y= -(1/2)
2x-4y=5
so 2x=5+4y
so 2x=5+4(-1/2)
so 2x=(10-4)/2
so 2x=6/4
so x =3/2
The value of x=3/2 and value of y= -1/2
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 03, 2010 | Office Equipment & Supplies
Can it solve 8^x=4 ???
You can use algebra to solve it.
Use the fact that 4 =2^2 and 8=2^3 and substitute in the equation
(2^3)^x =2^(3*x)
Then 2^(3*x)=2^2
By equating the exponents
3x=2 and x=2/3
Using the solve( function
With the calculator physical keys between square brackets, and the SHIFTed or ALPHA keys between parentheses, type in the following
8 [^ ] [ALPHA] [ ) ] (X) [ALPHA][CALC] ( =) 4 [SHIFT][CALC] (SOLVE)
Once the foregoing command entered press [=]
Display shows Solve for X on top line and probably 0.000 on bottom line.
Press [.] 5 to give 0.5 as a guess for the value of x
After a moment the calculator returns with the solution.
The display shows three lines
1st Line: 8[^] X =4
2nd Line: X= 0.66666666
3rd Line : L-R =0.
Your solution is 0.6666666. In fact the exact solution is 2/3.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-115ES Scientific Calculator
How to use ti 89 with a problem like "-(3x+1)-(4x-7)=4-(3x+2)'
Just plug in one side of the equation and find the answer. Then plug in the other side and compare answers.
Feb 19, 2008 | Texas Instruments TI-89 Calculator
How do i solve for x on my ti-89?
First to solve a problem, write it like this
solve(3/x-2+21/x^2-4=14/x+2,x)
Second, for inverse, do this (note the "y=" part)
solve(y=3x^2 -2x+1,x)
The calculator will rewrite the formula as x = ...
Oct 23, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments BA-II Plus Calculator Logo
12 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
