Question about HP LaserJet P2015 Printer
Prints "GET/DevMgmt/DiscoveryTree.xml HTTP/1.1 - why
2 Suggested Answers
  • 66 Answers
SOURCE: My HP M2727 nf always
If you send a print job such as word sometimes you actually have a second page but it will be blank. look at your document to see if there is a page 2.
Also under the settings of the printer you will find where it says copies, that needs to be set to one(1). If this is a network printer simply type in the address of the printer in the address bar of Internet Explorer and the printer will appear with all the settings and paper trays etc. If it has a screen on the printer go to configuration and look in there for "copies" then change it to "1"
Posted on Nov 28, 2011
It keeps randomly printing the following: GET/DevMgmt/DiscoveryTree.xml HTTP 1.1 HOST:
To resolve this behavior, clear the Document Properties check box. To do this, follow these steps:
Word 2007
  1. Click the Microsoft Office Button, and then click Word Options.
  2. In the Printing Options area box, click to clear the Print document properties check box, and then click OK.
Word 2000, 2002 and 2003
  1. On the Tools menu, click Options, and then click the Print tab.
  2. In the Include with document area, click to clear the Document Properties check box, and then click OK.
Nov 05, 2014 | Dell 2335dn Multifunction Laser Printer
Dymo\DLS8|printer Settings.xml access to the path is denied
Just remove PrinterSettings.xml and Settings.xml (in DataTracking folder). Next time you start the software it creates new files and the problem is gone.
Feb 04, 2012 | Dymo LabelWriter 450 Turbo USB Label...
My HP M2727 nf always prints a second page, GET /DevMgmt/DiscoveryTree.xml.... How do we remove this and stop wastinig all the paper?
Sep 17, 2011 | HP LaserJet P2015dn Printer
Windows says: Error 12, Backupdestinaton not availabe ?
Hope this will helps
1.Quit WD Anywhere Backup - right click on the icon in the task bar
2. Go to C:/Users/<yourname>/AppData/Roaming/WD/WDAnywhereBackup/instances
3. In there you'll find the folders containing each of your backup plans
4. Open the XML document in there using an XML editor (I used XML Marker - simple to use and free from http://symbolclick.com/xmlmarker_1_1_setup.exe )
5. You'll see a line in there saying "<Key Name="dest" Value="\\unknown xx-xx-xx-xx.lan\Public\My WD_Backup" />"
5. Change the 'unknown xx-xx-xx-xx.lan' to the name of your drive - Use WD Discovery to remind you if you don't know. It's the name in the left column
6. Save the XML
7. Do the same for the XML file in C:/ProgramData/MemeoCommon/autobackup
8. Restart WD Anywhere Backup and it should be working again
Oct 29, 2010 | Western Digital My Book Essential Edition...
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
Javascript code equivalent to PHP given below.
You can load a XML fie from JavaScript like this:
var xmlDoc = new ActiveXObject("Microsoft.XMLDOM");
function loadXML(xmlFile)
xmlDoc.async="false";
xmlDoc.onreadystatechange=verify;
xmlDoc.load(xmlFile);
xmlObj=xmlDoc.documentElement;
http://www.sitepoint.com/article/server-side-xml-javascript/
Apr 30, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
HP LaserJet P2015 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
