FixYa.com
Tags:
Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto (by 4 users)
posted by Terena on Sep 26, 2007
I have a problem with my steam cleaner. Cannot get steam to come out, and the big valve at the top just keeps turning in both directions. So can't empty it. I have'nt got an instruction manual either as it was given to me. Any suggestions!!!
Terena
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 21, 2008
POlti Vaporetto 2400
Comment by Guest, posted on Jan 08, 2008
no steam tried by emptying out water
Comment by Guest, posted on Dec 20, 2007
vaporetto2000
no steamcomming out
Best Solution
posted on Dec 04, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
polti vaporella 4500r
hi i have a vaporella 4500r... Answer This...
cable for polti 2400
I need a new cable for the... Answer This...
Polti Vaporetto steam Cleaner
Model Number VT2400 Serial... Answer This...
I have a Polti Vaporetto
I have a Polti Vaporetto 1030... Answer This...
polti spares
polti spares Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
