Question about Neff R4381 Electric Commercial Dryer
Neff dryer dryer switches itself off and all of the lights on the electronic panel flash on and off
  • Anonymous Mar 14, 2014
    Indicator lamps do not light up when switched on. Light inside drum is on so there is power. Temperature limiter is OK. Where is the problem ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Need to know the manufature and model number to help on this one. also if possible note what lights are flashing and how many times. It could be giving a fault code.
Posted on Sep 26, 2007
SOURCE:
Neff condenser tumble dryer indicates resevoir full although it is empty
It sounds as if the micro switch is stuck....if you can take off a bottom panel at the back or front you should be able to see it on top of the reservoir but don't be too heavy handed as they're very delicate "MAKE SURE THAT IT IS UNPLUGGED ".
Nov 05, 2017 | Neff Dryers
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
A Neff warming drawer red light flashes
There is a 'plug and socket' connector at the back of the warming drawer which does wear and eventually start to make erratic or no electrical contact. The drawer electronics read this as an open drawer and switch off the power to the heating element (flashing red light). If your competent the drawer can be stripped down and the contacts serviced or replaced otherwise consult a service technician.
Dec 07, 2012 | Neff Ovens
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Whirlpool Duet GGW9200LL1 will not start
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Jan 14, 2009 | Dryers
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Oct 07, 2007 | Neff V4380X0 Front Load Washer / Dryer
Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Mar 24, 2007 | Neff V4380X0 Front Load Washer / Dryer
Neff R4381 Electric Commercial Dryer Logo
234 people viewed this question
Top Neff Dryers Experts
gbob59
ray gallant
ray gallant
Dayton Computer
Dayton Computer
Are you a Neff Dryer Expert? Answer questions, earn points and help others
