Question about Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
Jandy aqualink rs beeping - Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux) RSP8 ()
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need more info does it have a aqua pure if so it must no0t be working turn chlorine production to 0 and it will not beep
Posted on Sep 25, 2014
3 Suggested Answers
adamh294
  • 310 Answers
SOURCE: Have a 3.5 year old Jandy Aqualink RS 4 --- the
It is most likely not a bad reading on the on the display.
One culprit of a false temp reading could be:
If the temperature sensor is installed after the heater and the circulation pump is clogged or failing, this would allow super heated water to reach the temperature sensor and give you that reading. However, most pool/spa heaters have a high limit switch that would shut down the heater @ 150 degrees F. So this is also unlikely.
The most reasonable answer is to replace the temperature sensor.
If you refer to page 22 in this manual http://www.jandy-downloads.com/pdfs/Allbutton_manual.pdf
you will see that the temperature sensor is installed on terminals 5 and 6.
Trace these wires. They will goto a thermowell (which holds the temperature sensor) either in the pool plumbing, or to a temperature sensor in the heater itself. Temperature sensors when in the heater are located typically above the inlet/outlet header. There will be some disassembling required to access it in this case.
If it is in the heater and you need more help, e-mail me @ adamh@newconceptchem.com
Please take the time to give me a positive rating on this post if I have helped.
Thanks
adam
Posted on Nov 02, 2010
Testimonial: "Thanks for the prompt response. I'm at work now but I will follow your instructions when I get home. I had a feeling that it is a 'bad' sensor. "
  • 84 Answers
SOURCE: On Jandy Aqualink RS display it says 6700 Rev C
6700 REV C is usually the control boards and in rare cases the wiring between the two. Here is a post to troubleshoot http://goo.gl/4Hp7k. It also points to www.fixyourboard.com. Bottom line, don't buy new, get them fixed.
Posted on Mar 01, 2013
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
I have a Jandy aqualink rs pda,
go to the aqualink and pressthe button below auto and service put in auto then turn PDA on
Jun 28, 2014 | Jandy AQUALINK RS TELELINK KIT
Solar has disappeared from my Jandy Aqualink RS control
go into system setup assign the solar to a aux it should work
Apr 10, 2014 | Jandy Aqualink Rs4 One Touch Control...
Why does my aqualinks pool panel beep
do you have a aqua pure chlorine generator if so turn to 0 until water is balanced
Jun 15, 2013 | Jandy AQUALINK RS TELELINK KIT
I have a jandy AquaLink RS PDA screen that has Handheld 1.38 and ----Waiting----- on screen. Anyway to reboot?
shut everything off turn aqualink back on then turn on PDA if still doesnt make sure wire to antenna not cut
Mar 27, 2013 | Jandy PDA-PS8 Aqualink RS PDA PS8 Wireless...
Jandy aqualink RS is beeping every minute. What does that mean?
if aquapure is not working just turn production to 0 then get fixed
Oct 09, 2011 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink RS
Disconnect the spa side remote.
Jul 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Jandy AquaLink RS OneTouch RS8 Pool or Spa Only (Pump Heater + 8 Aux)  RSP8 () Logo
103 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
