Question about Kenmore Refrigerators
I have a Kenmore 795.72033.111 that just had a new compressor put in. My ice maker is not working now eventhough it says on and my front panel does not work. (I can't do energy saver mode, change temp, nothing.)
SOURCE: FRONT DISPLAY SHOWS (PE0-000)
TO KEEP YOUR FRIG WORKING UNSCREW THE TOP LEFT HINGE COVER AND PULL APART THE PLUG, FRIG WILL CONTINUE TO COOL TILL A REPLACEMENT BOARD IS INSTALLED.
Posted on Oct 01, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
SOURCE: kenmore coldspot ice maker quit
On a similar note I have the unit with the control boards in the side. The RH (LH when looking at the front of the unit) board appears to be just just an LED module. Is this LED emit in visible light or in IR? There is no light visible even when holding the door light switch shut.
Posted on Dec 06, 2009
Ice maker stopped working in a kenmore refriderator model 106 57032602
take the cap off the front of ice maher. turn the gears manualy in either direction about 1 turn put cap back. if that doesn`t work replace ice maker. MAKE SURE tube goes backon top of ice tray.
Dec 26, 2017 | Kenmore Refrigerators
How can i get the error 15 msg off my Kenmore Refrigerator panel?
Contact the service man and have him make it right with you.
Dec 11, 2014 | Kenmore Refrigerators
I have a kenmore model # 106.54582400 that has been moved and not plugged in for 3 months , i cleaned it all up like new and plugged it in and now its not cooling , its never been on its side , the motor...
The compressor freon got leaked or compressor got damaged while shifting.Get the compressor inspected.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Kenmore Refrigerators
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
Kenmore Elite fridge Ice Maker quit spitting out ice. There are ice cubes in the maker, but it wont release them to the bin
One thing you can do is clean up the condenser coils, the toe kick plate, and the area around the compressor to where the air flows better and it might start working.Other than that your ice mold thermostat inside the ice maker itself could be bad. They are not to hard to replace on modular type ice makers: themobilian_2492.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 24, 2011 | Kenmore Refrigerators
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Sep 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker
water valve on back of refrigerator
the water line connects to it
it is leaking a tiny amount of water and it freezes
in the inlet tube to the icemaker.
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge: not making ice, no water in ice maker
look to the water inlet valve behind refrig sound like you got a frozen line, or a bad solenoid
Feb 19, 2008 | Refrigerators
Refrigerators Logo
107 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
