Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson Stylus cx6600 printer not printing
When i stwitch on the above printer, and start to print it prints empty paper and the screen reads Error, please load paper. I have enough paper in printer,Also copier and scanner not working. I have changed catridge and checked all connections to my windows vista PC. Thanx Belowzero
  • 3 more comments
  • kevin68 Nov 14, 2007
    No ink is showing on he paper when printing or copying. I have changed ink cartridges, cleaned the nozzlesand tested the nozzles. Even during the tests no ink is printing. When I print it sounds like its printing but nothing shows p on the paper.
  • smilinja Nov 15, 2007
    I seem to be having the same problem as Kevin except my black and yellow won't print. The cyan and magenta print on the nozzle check page. I have cleaned the nozzles, changed out the ink cartridges, uninstalled and reinstalled the software and it still won't print the black and yellow ink.
  • mali fflur May 12, 2008
    my cx6000 will not print and it will not load the paper or push it in
  • kidlove2006 Nov 03, 2008
    lost my cd to Epson Stylus cx6600
  • dleetch Nov 03, 2008
    PRINTER WILL NOT PRINT EVEN AFTER NOZZLE ALIGNMENT, CLEAN NOZZLES, CHARGE NOZZLES.
My software cd got lost and i got a new computer so what can I do to install the Epson cx4400 software???
Posted on Jun 21, 2008
  • 163 Answers
Please remove un necessery data from your system and re install the printer som after it your problem will be finish
Posted on Sep 26, 2007
Epson stylus cx6600. How can I get rid of the message box telling me I am not using Epson carts. I know they are not Epson carts but there must be away of having not to click YES I want to continue using...
Hi Andy,
This helps remove the nag screen:
  1. Go to Printers and Faxes (or the equivalent screen that lists all your printers)
  2. Right click your CX6600 printer and choose "Printing Preferences"
  3. Click on the "Maintenance" tab
  4. Click on the "Speed & Progress" button
  5. Tick the "Disable EPSON Status Monitor" checkbox
  6. Click on OK
  7. Click on OK to close the Preferences window
That should sort you out and allow you to print in relative peace...
Cheers,
Martin
Jan 18, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Bypass out of ink error on Epson CX6600
You can't bypass it. It need in in all cartridges, even though you are just printing black n white.
Weird eh?
Good Luck :0)
Nov 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I press print. It acts all busy and loud. Prints NOTHING
If paper is feeding through and you don't get any errors try this: Try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Not printing
Epson printers Will NOT print with any empty cartridge installed.(any Colour) replace the empty carts and you should be on your way
Mar 24, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Sep 01, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX6600 printer error
Remove the Print ink cartriges. Get a new bottle of windex and using a eye dropper place some windex on the post where the ink sits. also place some windex on the area that the printer uses to clean the print heads. leave it for an hour or two, You might have to do this several times. If problem persists do above treatment and leave over night. Hope this helps.
Dec 04, 2006 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
730 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
