Question about Daewoo L700C 17" Flat Panel LCD Monitor
SCREEN MESSAGE - MODE NOT SUPPORTED
Not a Daewoo LCD I have problem with but a Philips. After an attempt to change the screensave and settings, all I get is message : MODE NOT SUPPORTED H:33:7KHZ V:60:OHZ - is there anything I can do to get my screen back please! Desperate!
  • 363 Answers
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Posted on Sep 26, 2007
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Restart the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears.
Posted on Dec 21, 2013
Dell LCD Monitor will only work in safe mode - otherwise I get the error message Can't Display this Video Mode. I have reset to factory settings and also tried manually setting it to 1280x1024. When...
This Dell E153FPf 15" TFT can olny handle max 1024 x 768 @60Hz that is why you are getting the message ont the screen.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 03, 2011 | Dell E153FPf 15" TFT LCD Flat Panel...
OSD + GNR 19M1 LCD screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Dec 22, 2009 | GNR 19M1 19" LCD Monitor
I can't get my Philips Aria mp3 player out of demo mode.
Use next information to page in the players menus:
Go to
Settings >
Display settings >
Screensaver >
Demo Mode
Select Demo Mode and turn off the demo mode.
Dec 13, 2009 | Philips Audio Players & Recorders
Philips tv
go in menu and change it to home
May 27, 2009 | Philips 52 In. LCD HDTV
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Getting frequent black screens on 1501 Inspiron Laptop
Black screen is probably a screen saver or the screen is turned off by power management software.
Check your screensaver setting. Change the screensaver to None to disable screensaver.
I assume you are using Windows XP.
If the LCD is turned off by power management, on the same screen with screen saver, on the lower part of the box there is a Power button. Click to open Power Options Properties. Set your monitor power properties there.
When the screen go blank and you have to push power button, probably the computer is set to go to stand by mode after some idle minutes. You can also set it here in system standby setting.
Regards,
Dapid Candra
Dec 08, 2008 | Dell InspironTM 1501 Notebook
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
Daewoo L700C 17" Flat Panel LCD Monitor Logo
834 people viewed this question
Top Daewoo Computers & Internet Experts
General Systems...
Paul Bade
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
