Question about Sewing Machines
Janome js1008 thread
Top thread jams
bargainbox
  • 1388 Answers
SOURCE: embroidery machine janome 300.
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 3 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Dec 28, 2008
  • 240 Answers
SOURCE: top thread breaking during sewing.
Your top tension may be too tight or it could be incorrectly threaded. Check threading and ensure you are using a good quality thread. Cheap threads breaks without a reason!
Posted on Jun 11, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: Janome 1600P:top thread shreds.Ihave done all
You have adjusted the tension? aligned the needle? Bobbin moves freely? Needle height is adjusted properly?
Posted on Jan 13, 2010
My machine janome jf 1004 is jammed and the wheel won't turn. There isn't any thread caught anywhere
Have you removed the sewing plate and looked underneath feed dogs an bobbin for jammed thread or lint buiod up? :)
Mar 30, 2017 | Janome Sewing Machines
I am using upholstery thread in my Janome HD1000 and it jams
UPHOLSTERY THREAD IS A LITTLE THICKER. THIS MEANS YOU NEED TO LOWER THE BOBBIN TENSION. WHEN YOU LOWER THE TENSION THE BOBBIN SHOULD BE BOBBED ON YOUR FINGER AND ALLOW IT TO EXTEND ABOUT ONE INCH WHEN IT IS RIGHT. THEN YOU WILL NEED TO MAKE THE TOP TENSION TO MATCH THE TENSION SO TRY A SCRAP AND ADJUST IT AS NECESSARY.
Jan 17, 2015 | Janome Sewing Machines
Open helpline
Like the last pair of photos here? http://www.picturetrail.com/sfx/album/view/22521551 Clean the machine, rethread from scratch with the presser foot UP while you're threading the top of the machine, fetch up the bobbin thread, and hold the bobbin and top thread ends together behind the presser foot while you're starting each seam -- just for the first 2-3 stitches of each seam.
Jan 25, 2014 | Janome Sewing Machines
check to make sure the top thread isn't coming off the thread take up lever
also make sure the bobbin is turned the right way in the bobbin case
make sure the needle is turned the correct way in the needle holder
also try a different bobbin
if none of these suggestions help, then it would be a good idea to have the machine checked for a timing problem
Oct 17, 2013 | Sewing Machines
Jamming
try changing the needle
rethread the machine top and bobbin
even try a different bobbin--make sure the bobbin is turned the right
way
make sure the top thread has not come off the thread take up lever
Dec 22, 2012 | Sewing Machines
My Janome 6500p is having bobbin issues
here are my suggestions
1. when your sewing check to see if the thread is coming off the thead take up lever,, I've had this to happen to me & it can jam a sewing machine up
2. it's possible that the bobbin case is worn & needs to be replaced
3.also check your top tension
4. try rethreading the machine top thread & bobbin
Feb 06, 2012 | Janome Sewing Machines
The underside is sewing with loops and then gets jammed..?
first try pulling all the threads out and rethreading. look for anything jamming the guides. try threading the top of the machine then cutting at the cotton real and pulling the thread out towards the needle, in the direction the thread should run. A good clean would not hurt.
Sep 12, 2010 | Janome Harmony 2041
The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Janome Sewing Machines
Bobbin is not filling. It barely turns.
This happened on my Janome 10000...it had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
