Question about Canon IMAGERUNNER 6570 Copier
How to set paper tray ir 6570 - Canon IMAGERUNNER 6570 Copier
4 Suggested Answers
  • 385 Answers
SOURCE: how to change the setting for the paper tray
Hey!Its either a round knob that u can turn to the size paper u want or a slide blue lever u can adjust!Good Luck!
Posted on Dec 08, 2010
babaprithi
  • 372 Answers
SOURCE: my IR 6570 feeder only
check the legal size on the glass and measure it with ur paper.this is common problem as these machines are designed for specific country papers and most times the legal paper of different countries differ .no solution dear .try using the bypass tray
Posted on Sep 19, 2011
sodeep
  • 3267 Answers
SOURCE: ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
Posted on May 07, 2012
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
I need to set my Cannon IR 6570's Tray 1 & 2 into A4 it is in LTR please tell me the solution to change it to A4
code for changing LTR to A4
*28*
copier
option
then goto CST
change reading from 18 to 6 in both
it done
Jun 19, 2014 | Canon IMAGERUNNER 6570 Copier
Remove paper from booklet tray
You have a booklet maker and it is at the bottom of your finisher .its the tray at the very bottom of this unit. What i have seen before is that it gets kicked or the cleaning crew hits it and knocks the tray out of allignment. And when this finisher starts its initial rotation (warming up) the tray will seak a home position. it also has a sensor that detects the presence of books . It will hold 10 or 15 books and then you have to unload and continue. So look down there and inspect the tray, keep it simple it is most of the time. and remember what happened when it started this issue. If all else fails unplug and check your connections restart your machine.
Dec 04, 2013 | Canon Toner Cartridge For Cnm Ir 6570,...
My IR 6570 feeder only detect A4 paper and not F4/Legal paper and some times misread the paper
Sep 16, 2011 | Canon IMAGERUNNER 6570 Copier
CanonPC6RE
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
May 15, 2008 | Canon IMAGERUNNER 6570 Copier
Canon Imagerunner 6970
Hello. To start with, you have indicated that you have a "6970" canon copier. I am unaware of the existence of that model and will therefore assume you meant 6570. I mean no disrespect in this clarification if it is indeed appropriate. With that in mind your problem with the copier may be quite easy to solve. Unless you have had a professional field engineer recently service your machine and totally "reprogram" the device which would cause a need for calibrations that are usually unnecessary then here is the most likely cause. You should have a minimum of four paper trays in which tray 1 and 2 are strictly letter size. Trays 3 and 4 are "universal " trays that allow the customer to configure the trays to any size they wish. Depending on the setting of the side guides of the paper tray that hug the paper from the rear and the front and the end guide that snugs against the left side or "trailing" edge of the paper (these are necessary to make sure the paper is secure and does not "float" around in the paper tray) the copier should "recognize " the size of paper it will be feeding. If any of these 3 paper guides are not positioned properly then the copier can and will incorrectly read the paper size in the tray as soon as you shut the tray the copier will then modify the image to fit (or not fit) the original to that paper size .U2 , in brief, is a "custom " size and is rarely appropriate. In the event the copier has in fact had a significant circuit board or programming change then the copier will not read the position of these paper guides correctly. Lets hope it is the former as the latter will be a service call that requires a trained technician to re-calibrate the copier. To conclude, check to make sure the guides around the paper are securely against the paper.I hope this helps.
Dec 20, 2007 | Canon IMAGERUNNER 6570 Copier
152 people viewed this question
old marine
old marine
