Question about Refrigerators
Samsung rf266 ice maker
Ice maker produces ice but then extra water flows into tray and it all freezes into a big clump
SOURCE: auto ice maker
reduce water fill, small adjustment screw on side of power head, clockwise for decrease, maximum one full turn. if that fails, remove i/m and check for cracked mold, fill with water and place on level table under paper towel. if ok, replace module.
Posted on Sep 15, 2008
  • 115 Answers
SOURCE: to much water injecting in ice maker
you can not adjust it enough if it is overflowing I would try a new water valve first cause it is cheapest but if it dont fix it then get a knew icemaker
Posted on Dec 30, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My Jenn Air refrigerator ice maker is dripping
Unplug water control valve for the ice maker side on rear of freezer. If water continues to flow replace the water control valve If you already tried that the bring me up to date on just what you have tried and how long this has been happening. Sea Breeze
Posted on Oct 25, 2009
tzweeb
  • 318 Answers
SOURCE: ice maker over fills the ice cube tray over
most likely the i/m needs replaced. what happens is the coating inside the mold is peeling off and causing the cubes to stick and then melt the cubes instead of releasing them. when this happens it will cause the unit to overfill the next cycle and leak into the bucket.
Posted on Jan 07, 2010
heatman101
  • 43501 Answers
SOURCE: ice maker will not produce ice, no water flowing.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
I noticed that my ice maker continues to flow water into tray causing a big ice block could it be that i have a water leak in the freezer
Ome cause might be water from the ice maker is over flowing caused by 2 problems: 1 it could be a wrong calculation of water from your ice maker electronic board or 2 water solenoid to your ice maker is leaking .
Jan 30, 2013 | Samsung RS2630SH Side by Side Refrigerator
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
My ice maker runs extra water out and creates a big block of ice in the ice drawer. what is causing this to happen?
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then more water will enter the ice maker and this water freezes and big block of ice gets formed.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 01, 2011 | Maytag Refrigerators
My Jenn Air refrigerator ice maker is dripping water out of the front right side (one drop at at a time) into the ice tray. The water causes the tray to freeze up into big clumps. Any suggestions on what...
Oct 25, 2009 | Jenn-Air JCD2295HES Side by Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
To much water injecting in ice maker
Dec 30, 2008 | GE GSS20IEP Side by Side Refrigerator
Auto ice maker
Jul 07, 2008 | Maytag MZD2766GES Side by Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
