Question about Bosch Dishwashers
My Bosch dishwasher comes up with an auxillary heating error fault, please help me, what needs to be done.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Temporarily you can run the machine in the cold water mode . Heater may have shorted to ground and will need to be relaced
Posted on Oct 17, 2013
Testimonial: "THANK U OSCAR FOR YOUR TIME AND ADVICE, THE TECH SAYS THE HEATER IS FINE BUT HAS TO DO WITH THE FANS, COULD THIS BE THE CASE? AS ALL THE PC BOARDS HAVE BEEN REPLACED."
  • Oscar Netto
    Oscar Netto Jun 13, 2014
    I would go with the techs advice, replace fan motor
Bosch dishwasher code E19
E:19 Dispenser fault End of program Dispenser defective Check component Wires interrupted/broken Check wires
check out the website for more/ you may have to go on youtube to figure out how its done.
Bosch Dishwasher Error Codes and Solutions Toronto Appliance Repair Service
YouTube
Oct 24, 2017 | Bosch Dishwashers
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch error code e22
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Feb 27, 2013 | Bosch Dishwashers
My bosch dw gives a error code of 1 this is an over or under water filling fault not a heating error which is posted on this site which one is correct
Hello, welcome to Fixya. Actually an error code "1" refers ONLY to a heating error. I'm not sure what you've based your info on, but "1" being displayed has nothibg to do with a water fill/level issue what-so-ever with any Bosch dishwashers. Here's how to perform a test or diagnostic for the "shu43" series Bosch to determine once and for all the problem you're having though. Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ). Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ). When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time. Let the test follow through. When testing has ended, the display will show an error using codes as follows. "0" = no error. "1" = aqua sensor fault. "2" = heating fault. "4" = filling fault. and finally, "8" = NTC ( temperature sensor ) fault. If it where related to a fill/level error you would see the letter "F" during washing but the # 4 in diagnostic's. Similarly for a heating fault, the diagnostic will identify a #2 but the "1" appears during normal washing. Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating. If there is anything not clear let me know and I'll try to expand on the info I posted. Good luck. Macmarkus :)
Jun 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Error code 01 on bosch dishwasher. what does this mean?
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
May 27, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch dishwasher running to long and not sanitzing dishes
Sounds very much like an element fault. Locate and test continuity of the element
Jan 02, 2018 | Dishwashers
Dishwashers Logo
114 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
