Question about Dometic 3313189.000 White Single Zone LCD Thermostat with Controls Kit Heat/Cool/Fan
Just bought new A/C unit and had it and new controller mounted on wall now it cools to the right temp. then go off and in a sec. comes on the in a sec goes off then comes on runs for awhile then goes off sometime comes on but then not
    Genius:
  • Dometic Master
  • 1,363 Answers
Sounds like communication cable issue.between relay module and thermostat.
Posted on Aug 17, 2015
3 Suggested Answers
daddyo742001
  • 70 Answers
SOURCE: Both roof top units on RV cool for awhile the go off
May be low voltage problem or bad connection this may cause controller to shut one or both down. Need to talk to RV dealer for assistance on this system.
Posted on Jun 28, 2009
  • 49 Answers
SOURCE: Where can I purchase the 12 volt wiring that looks
The best place to get your 12 wire is Lowes and Radio Shack.
Posted on Jun 05, 2011
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Can i us a wall mounted air conditioner to build a small cool room for chilling lamb
Hi, correct me if i am wrong, but you want to use a wall mounted a/c to chill Lamb or other foods? Well, air conditioners are considered De-humidifiers, and medium temp. units, so if you cleaned out this room and put in the right materials on the walls and ceiling, you would have to maintain a safe temp 38*F and use this product as I am not sure what the shelf life would be? Check the sq. footage and get a unit more than large enough to maintain this temp. I know on a walk-in Refer, health inspectors want these boxes to be maintained at 38*F, and you can't accomplish this without modern refrigeration equipment. To chill it for a short time, maintain that temp and keep for you're own use.
Sincerely,
Shastalaker7
Nov 17, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
I want to wire digital wall mount thermostat to my window AC unit
I think you are wright and also may lead to short cycle and burn the start relay on compressor(it may be too hot to be without air just now)try bigger relay when it is a bit cooler and 24,000btu must220-240 volts be very careful
Aug 20, 2009 | Heating & Cooling
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Wall oven too hot,at 350 setting is almost 400 degrees burns food
I have a very old GE wall mount oven. Original to around 1960. You can take the temp control knob off and there is an adjustment on the back of it. Easy peasy and only need a screwdriver.
Dec 05, 2008 | Frigidaire Kitchen Ranges
Q-Star Compressor
The compressor just seized, so I just bought a new much more efficient unit.
Jul 28, 2008 | Friedrich QStar SQ05J10B Air Conditioner
Dometic a/c, duotherm thermostat, turns right back on after it reaches desired temperture.
I have a dometic 13500 BTU Roof mount a/c. It is set up with the duo-therm analog thermostat. The system cools fine. The problem is that the a/c gets down to the right temp, then it turns off like it should but turns right back on within a few seconds. Any help would be greatly appreciated.
May 13, 2008 | Dometic Rooftop RV Air Conditioner
Dometic 3313189.000 White Single Zone LCD Thermostat with Controls Kit Heat/Cool/Fan Logo
74 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
