Is there anyway to add another hard drive? Like an external one? Because time has taken affect and what used to be 52gig is now 1gig!
I have basically no memory left. Also, I noticed on my computer as well as my normal hard drive(C:) there was a D: ...
It had around 20gig free and I dont know if I should save things to it or not.
I need a new memory device which I can store movies, graphics and tons of music on. I also have a lot of programs.
Please help, thanks. (:
An external drive would be a possible solution. You could also buy a new internal drive (be sure it is the same interface), buy a 2.5" external usb case, and mirror the data over to the new one. You could then install the new drive into the computer, put the old one in the external case and either use it as a backup or an external drive.
As long as that one has the same interface as your Dell it will work. From the description however I can't tell what interface it uses.
http://www.directron.com/st9320320as.htm...
http://www.directron.com/st3160813as.htm...
http://www.directron.com/2518uas.html
You would get a SATA drive (all the research I have done shows that your dell uses a 2.5" SATA 5400 rpm drive), put it into the enclose and run this, http://www.miray.de/download/sat.hdclone...
You can then copy your main drive onto the USB drive, the software is fairly straight forward, just be sure you are copying from the right drive. Once that is done, you can take the drive out of your computer and swap it with the one in the enclosure and bam, you are upgraded.
Yes, those products should work just fine for you.
ok thanks for the help im looking at some now...
http://www.amazon.co.uk/Toshiba-250GB-2-...
would that be suitable?
sorry for the hastle..and how could i set that hard drive as my main one?
So Id get them? (the top one and the bottom one) put the hd in the enclosure then plug in by usb...then use that site to transfer my old hard drive crud onto the new one...and then id take my old one out? then put the external one inside...? sorry im awful with commys.
sorry got it now:D
Sorry i get the process and stuff its just that im in the UK and wont be able to get the products you said to but i think these are alternatives...
If so could you please tell me:D
sorry again
http://www.amazon.co.uk/StarTech-com-Inf...
http://www.amazon.co.uk/Western-Digital-...
