Question about Vollrath 59500P Mirage Pro Countertop Induction Range
Vollrath Mirage Pro Induction Range temperature control does not work
How do I fix an Electrolux induction range element that is not at full power?
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
Feb 18, 2015 | Electrolux EW30IS65JS - 30"Electric...
I have a prima induction single hob and haven't got a clue how to use it , haven't got the manual , help please
You need to have pots and pans that are verified for induction cook tops. Ordinary pans will not work. Once you do that it works like any other burner only you can control the temperature precisely. You can melt chocolate without burning it as well as deep frying foods without ruining the oil from excessive temperature. Try looking for the manual from the manufacturer's web site.
Nov 19, 2014 | Cooktops
How to calibrate kenmore meat probe? it says 170degrees when plugged in cool.
170 degrees is likely the minimum it can read. put a container of water in the oven, put the probe in the water, and set the oven for 250 degrees. Watch the probe, and see what temperature it shows when the water boils. Depending on your altitude, it should be 212 or a little less.
Sep 04, 2014 | Kenmore 30 in. Freestanding Induction...
What does electrolux stove induction error code E21 mean?
Did u ever find out.mine is doing the same.ive searched everywhere and can't find an answer
Jun 23, 2014 | LG range & stove induction cooktops...
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
We have as Whirlpool FXTM6 induction oven .. (and no manual). The display stays on 'STOP' no matter what you do.. how do i get out of this?
We discovered if you press in both the oven control knob and the temperature control knob simultaneously for several seconds, the stop message goes away and the oven returns to normal.
Jan 27, 2013 | Whirlpool Cooktops
F11 reading on control panel of electrolux induction range
Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Vollrath 59500P Mirage Pro Countertop Induction Range Logo
19 people viewed this question
Top Vollrath Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Vollrath Cooktop Expert? Answer questions, earn points and help others
