Question about Sewing Machines
My bobbin cartridge was jammed now machine is slow. singer 347
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
  • 69 Answers
SOURCE: On my Singer Scholastic, the thread jams in the bobbin area
It sounds like it is not threaded properly through the tension disc. Try rethreading and make sure the presser foot lever is in the up position. If it continues, once threaded and with the presser foot down, pull on the thread through the needle. If it has resistance, it is threaded properly. If it pulls easily then there is a problem in the tension area. Check to see if there are peices of thread broke off in between the tension disc.
Posted on Feb 07, 2009
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
Singer 3116 machine has jammed. Can not turn wheel to move needle.
make sure there isn't thread jammed in the hook take out the bobbin case and look
Nov 14, 2017 | Singer Sewing Machines
Machine sewing too slow,
Sewing to slow
the leading causes of a sewing machine running too slow are the following: "Thread jam, Incorrect oil or lubricant used, Not lubricated correctly, Machine unused for long time - Gummed up, Belt too tight or too loose, Machine needs thorough cleaning, Worn or bent parts."
Unplug the machine. Look for thread wrapped around the motor shafts or any other motor or bobbin part. Use tweezers to lift thread to snip with scissors. Use tweezers to pull the thread away from the machine parts. Plug in the machine and test.
Unplug the Singer machine. Remove the bobbin and insert a newly wound bobbin. Blow the dust from the bobbin area. Use tweezers to pull out any thread pieces in the bobbin area gears. Plug in machine and test
How often you will need to clean and lubricate the machine will depend on how often you will use it. When in regular use, the machine should be cleaned periodically to remove lint and fluff which may have accumulated around the working parts."
could also be either the motor or the foot control.
May also need to be serviced.
Mar 19, 2016 | Sewing Machines
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
Singer - 241-12, bobbin thread not stitching
I have a 241-12 Singer. New to me. It was running great. Then the bobbin thread ran out. Put in one prewound bobbin that came with it, even though the bobbin appeared different. The bobbin thread didn't feed and the machine jammed up. I finally wound the old bobbin and put it in. It will only feed about 6" of thread before the bobbin thread breaks. It becomes so tight I can't get it to feed. Both bobbins will not feed. However I don't believe it's the bobbin tension because thread will pull through fine when pulled manually (if it hasn't been in the machine yet). What am I doing wrong?
Sep 15, 2013 | Singer Sewing Machines
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
HOW TO I WIND BOBBIN ON SINGER 347
If you mean the Singer Style Mate 347, open the face plate and remove the old bobbin. Then, the first step is to hold the hand wheel and loosen the stop-motion screw inside the hand wheel. (Keep the hand wheel from turning with one hand and turn the stop-motion screw towards the front of the machine.) Place your empty bobbin (hole away from the machine) on the spindle near the bobbin winder switch. Feed the thread from the spool on the spool pin through the eyelet on the top of the machine (near the top thread take up) and then down to and around the bobbin tension disc below the on-off power switch. Pass the thread through from the inside of the bobbin to the outside of the bobbin. Move the bobbin winder switch to On and hold onto the end of the thread. Start the machine and let a few winds get placed on the bobbin then stop for a minute. Cut the thread near the bobbin. Restart and continue winding more thread onto the bobbin until you have enough thread or the bobbin is full (it will stop automatically). Move the bobbin winder switch to off and tighten the stop-motion screw.
For pictures, see pages 6-7 in the manual. It's available as a PDF here: http://www.singerco.com/uploads/download/9b8c1ca7584c2bea7837ca4bf5338af7f1b5380e.pdf . (These are pages 8-9 of the PDF.)
I hope this helps.
Jun 06, 2013 | Sewing Machines
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
Singer 7470 jams and buzzes
To learn how to solve bobbin jam and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Dec 22, 2008 | SINGER 7470 Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
