Question about Moen YB2808 Eva Paper Holder - Chrome
Detach mounting bracket from moen eva toilet holder
  • 15307 Answers
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Posted on Apr 18, 2010
agent91
  • 2100 Answers
SOURCE: HOw do I remove the moen toilet paper holder from
Without looking it up, I can figure it has a tiny screw on the flange bottom, and when it is loosened, it will come off, then the holder, keeper, is screwed to the wall. If it is not held on by a little screw, setscrew, then try turning the whole thing off, it might be threaded. Hope this helps.
Posted on Jun 12, 2010
aviral_srms
  • 1216 Answers
SOURCE: My Moen Monticello Toilet Paper
  • 1 Remove toilet paper from the toilet paper holder.
  • 2 Examine the toilet paper holder to locate the screws that hold the toilet paper holder to the mounting brackets located behind the faceplate. Use a screwdriver to remove the screws. If you cannot find screws, the toilet paper holder may slide onto the mounting brackets. Gently pull up on the faceplate to slide the toilet paper holder off the mounting brackets.
  • 3 Unscrew the screws holding the mounting brackets to the wall with an appropriate screwdriver. If the holes are stripped, or the screw turns but will not back out, use your fingers to gently pull the screw out while turning to reduce damage to the drywall or enlarging the holes.
  • 4 Tap the hollow wall anchors into the holes with a hammer until the drywall anchors are flush with the drywall.
  • 5 Place the mounting brackets on top of the hollow wall anchors and insert the screws that came with the hollow wall anchors through the toilet paper holder mounting brackets and into the hollow wall anchors. Tighten the screws with a screwdriver.
  • 6 Place the toilet paper holder faceplate on the mounting brackets and insert screws to secure the toilet paper holder to the mounting brackets or slide the faceplate onto the mounting bracket, depending on the type of toilet paper holder installed.
  • 7 Place toilet paper back in toilet paper holder.
  • Posted on Oct 10, 2010
    • 82 Answers
    SOURCE: Where can I purchase Moen Monticello Satine
    you should be able to purchase these all online at moen.com good luck
    Posted on Dec 17, 2010
    • 1739 Answers
    SOURCE: How do you get the
    The technical specifications and installation instruction for your product are available here.
    http://www.moen.ca/shared/pdf/yb2208sp.pdf
    At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
    You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
    Posted on Dec 22, 2010
    How do you remove the eva towel rack holder
    The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
    May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
    Moen eva tissue holder broke, how do we fix it?
    Specifications and Installation Instructions:
    http://www.moen.com/shared/pdf/yb2808sp.pdf
    Identify the parts needed and the part number from above.
    To order replacement parts:
    http://www.moen.com/replacement-parts/search?context=modelNumber&value=YB2808CH
    If your tissue holder has simply come loose it is likely the the wall mount will need to be replaced or at the very least tightened. You will need to remove the tissue holder from the mounting bracket. Insert a small flat screw driver in the square hold at the underside of the base of the mounting post to release the locking tab. Try to tighten the screw holding the mounting braket; if it will not tighten you may need to replace the wall anchor. Once the wall anchor is replaced you can reinstall.
    Apr 02, 2011 | Home
    How does the YB2808 holder detach from the wall? ......the above answer wasn't an answer....I need to know how to "unsnap" the thing....it IS NOT held on with typical allen screw, how does one...
    The anchor is put into the wall in a pilot hole, a mounting post is inserted into the wall anchor, Afterwards the mounting post is pressed firmly until it clicks to stay in the mounting post with the handle down. The locking tab on the mounting post is faced down to fit into the specific area to stay put.
    • If this was over tightened it will be difficult to get off.
    • Try moving the handle from side to side, while pulling the unit off.
    • If all else fails, put tape around the handle, then slide a flat head screw driver under neath, and lift up. the anchor bolt will now want to come out but it can be cut off. Push it back in. Repair the hole and try again if you are moving it anyway.
    Dec 10, 2010 | Moen YB2808 Eva Paper Holder - Chrome
    How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
    Nov 15, 2010 | Moen YB2208CH Brantford Toilet Paper...
    Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
    How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
    there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
    Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
    Moen YB2808 Eva Paper Holder - Chrome Logo
    145 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
