Question about Nokia 1100
Nokia care 66542 - Nokia 1100
My nokia 5130's keypad is not working what can i do for thid one
Why you had given to Nokia Care, What was the problem which take you to repair center.you should explain first.Hy, Chandraka, first thing make sure if your device is charging, if charge that means your device is working there is problem with keypad belt (which you need to change), so second you should not take your device in prior condition then before with Nokia Care, i think you should give responsibilty of this to Nokia Care.
Jun 29, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
My nokia xpress music 5220 when it is switched on it show only nokia how to solve it
it seems a problem with your nokia software, nokia 5220 is a series 40 it means this problem can't handle by 3 fingers trick so you need to go to nokia care center or nokia care point to make a hard reset of your phone..
hope it helps and please rate this post
thank you
May 13, 2011 | Nokia 5220 XpressMusic Cellular Phone
How to format nokia 2600c-2?
I think you should go to your narest Nokia Prirority . It is a store opened by Nokia itself . The next shop will be Nokia Care . Go to Nokia Care and tell them that you want to format your mobile . I told you to go to Nokia Care because even mobile phones have operating systems . If you see the steps to format your phone on internet , then it will erase everything , even the operating system and you wont be able to do anything on your mobile phone . In Nokia Care , they will format your phone and also install a new operating system in it , which you will not be able to download on your computer from internet .
Jun 12, 2010 | Nokia 2600
Nokia n 72 was hang & also airtel sim is not valid in my phone.
you have complaint about your handset in your nearest nokia care he can help you and you have satisfied with nokia care service.
Thanks.
Aman.
Mar 22, 2010 | Nokia N72 Cellular Phone
I want to do full format a phone memory because of virus
To remove a virus you must reinstall the firmware and that too through Nokia Care. The reason being that if Nokia Care does it then the whole firmware is rewritten and if you do it then only the new files are written thus leaving the virus behind. May cost you a little but the only way to remove virus is through Nokia Care.
Dec 28, 2009 | Nokia N70 Cellular Phone
Sir i have forget the security code of nokia 1650. i am from portugal. is there any master code of nokia 1650?
Hello
You must take the phone to a local Nokia care point to be unlocked or re-flashed.
Please find a close care point from this nokia care point finder
CLICK HERE
I'm sorry, as it is a thief protection there is no simple way to get past it.
Let me know if there is anything else I can help you with.
Thanks and Merry Christmas.
Ekse
Dec 19, 2009 | Nokia 1650 Cell Phone
Please send master security code for my nokia 1200 v 5.23 IMEI:355734028058548, PLEASE HELH ME.
nokia 1200 can not unlock manually if u forgot the security code. take it to nokia care.
Oct 25, 2009 | Nokia 1100
Contact service
I have nokia 7210. once i was hearing song then i was connected   head phone suddenly phone turn off, then it is say to only contact service. what i do now ??? please help me ,.....................
Oct 04, 2009 | Nokia 7210
Undue Delay serrvice- set is not replace evan after 100days
a simple solution.. THREATEN the CARE people by CONSUMER FORUM.GOTO THE CONSUMER FORUM AND FILE A CASE AGAINST THE NOKIA CARE with all the job sheet details and respondings u got from the CARE PEOPLE..
Aug 05, 2008 | Nokia N70 Cellular Phone
Charging problem
It's either a software fault or hardware failure. Backup everthing you want to keep then download and install the nokia software updater: www.europe.nokia.com/softwareupdate If this doesn't fix it then you will need to visit a nokia care point. Care points: http://www.nokia.com and select your country.
Sep 30, 2007 | Nokia 6233 Cellular Phone
Nokia 1100 Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
