Question about Boating
1994 stratos 285, engine has a ignition cut out problem at times.
2 Suggested Answers
  • 740 Answers
SOURCE: plymouth voyager 1994
what are the conditions outside when this happens ex:rain snow sunny doesnt matter.
Posted on Dec 25, 2009
The engine in my mazda b2600 1994 sometimes makes short cut offs in seconds time.i cant find the reason,please help me
comon proble is ignition switch. try moveing key slightly towards off. if vehicle dies, that could be your problem.
Dec 15, 2012 | 1988 Mazda B2600 Cab Plus
1994 jeep wrangler 4.0 idles fine but when traveling cuts in and out and backfires when accelerator is pushed, i do have a cold air intake and jet performance module just recently added
1994 Wrangler with 200,000 miles on the odometer. Similar problem here: Severe bucking and backfiring, and engine misses when traveling down the road. I did an entire tune-up (plugs, wires, distributor, distributor cap, and ignition coil), but got the same thing. I thought it was dirty fuel injectors, so, I poured a bottle in a few times on fill-ups. The final solution, was a bad alternator. My mechanic said it was sending voltage spikes to the computer, causing the engine bucking and back-firing problems.
Feb 21, 2010 | 1994 Jeep Wrangler
Plymouth voyager 1994
Dec 25, 2009 | 1994 Plymouth Voyager
Mercedes w124 E280 1994 model. The engine stalls at time at junction; cuts out on take off or stalls before it takes off at junction. Have replaced just MAF(Bosch) and replaced wire loom too, otherwise car...
check condition of spark plugs and wires.. they can cause cut out at take off.
I have problems with Bosch spark plugs. But I love the Bosch ultra premium ignition wires
Also check for vauume leaks, intake hoses tight.etc.
Oct 28, 2009 | 1994 Mercedes-Benz E-Class
My honda accord aerodeck es 1994 model starts but soon cuts off and won't start for a while. Someone said it could be a fuel relay problem. If so, can i possibly by-pass the relay? If o how?
too many possible causes - MAF, MAP, IAT, CTS, Vacuum Leaks, worn engine components (rings, valves, etc.) fuel pump/pressure, injectors, ignition system, timing, etc. Take it in for diagnosis.. may save you money
May 09, 2009 | 1994 Honda Accord
Cut off
I suggest you to check your brake boster if there is air leak, to do this, start the engine, press the brake and hold. Observe the engine idle while you are holding down, if the engine become running roughly or engine cut off, it means you have to replace brake boster. but if this procedure doesn't make sense, try to knock the fuse housingseveral times while the engine is running if the engine.if cut off while knocking, most probable there is loos fuse or relay. secure all the fuse and try to knock again, if the problem still excesting, try to wigle in deferent direction the wire loom around the engine bay especially the wire harness of crank shaft and cam shaft sensors while the engine is running. if stil can't find the problem check the ignition switch harness try to wigle as while. if the problem occure while wigling the wire harness definitely you have loose connection.
Mar 09, 2009 | 1994 Honda Accord
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
