Question about Pioneer CDJ-800 Turntable
Error 8302 - Pioneer CDJ-800 Turntable
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
FREE REBOOT/RECOVERY DISCS FOR IMEDIA A5518 UK
restart it pushing F8 a list will apear select last known good configeration it should sort it
Feb 11, 2012 | Computers & Internet
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Aug 04, 2010 | MSI P4M900M-L Motherboard
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
Ejecting and error
Reading error. Problem with lents take to Pioneer service dealer
Aug 25, 2009 | Pioneer CDJ-100S CD Player
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Tuning 8302 amp
The amount of power that youre going to run on those 5.25s might indicate that you need to turn the crossover to a higher cutoff frequency because they gonna want to kick pretty hard if your set too low - Sounds like you got it under control though flip it to high-pass(HP) and see how it does at around 100 HZ cutoff- be sure to turn off any bass boost on the amp though too- Let me know how them soundstream mids do- I have a set of subs that kick *** but i never have heard anything about their mids-good luck
Oct 18, 2008 | MTX Thunder 8302 Car Audio Amplifier
could be bad mosfets or outputs, needs replace
Aug 05, 2007 | MTX Thunder 8302 Car Audio Amplifier
Pioneer CDJ-800 Turntable Logo
26 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
