Question about Yard Man Garden
My yardman blower is leaking gas out of the carburetor, carb looks good
slohry
  • 87 Answers
SOURCE: Can't figure out type of carburetor on my leaf blower.
I have seen 2 different carburetors used on this unit. A Walbro and a Zama. You will need to get the information off the carb. (Walbro WYC-10 or Zama K39A) are the two I have seen, but you need to be sure what yours is. Then purchase the correct O/H kit and rebuild it.
Posted on Apr 12, 2009
SOURCE: i need the schematics for stihl gas blower [bg85]
I had the same problem with mine. And when I wasn't using it, gas would drip out of the tank until almost empty. When I took it to the Stihl dealer, it was actually just the gas lines leaking. They changed the lines and tuned it for $75. It looked to me like the carb also but it was not, just the gas lines.
Posted on Sep 15, 2009
Dolfoff
  • 148 Answers
SOURCE: how to rebuild craftsman leaf blower carburetors
If it is a ZAMA carb look here.
If it is a Walbro carb look here.
Hope this helps!
Posted on Sep 28, 2009
vincob
  • 718 Answers
SOURCE: need to adjust carb on
Try closing all the way, than open three turns and adjust by ear from there. Good Luck...
Posted on Jun 27, 2011
  • 640 Answers
SOURCE: Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Posted on Aug 09, 2011
Installed a new carburetor on stihl bg55 blower. primer bulb filling up but is not pushing gas into carb. no cracks in line filter is good. Have tried two new carbs with same result.
If the bulb wont prime you have a leak some where lines, tank, cap, if it is not air tight it will not pump.tank full of gas.
Apr 05, 2017 | Stihl Garden
I have an MTD 611 snow blower thats getting too much gas and its leaking from the carb even when not running
If this is the carburetor: http://www.mtdparts.com/equipment/mtdparts/951-14026a
Check to make sure the float bowl on the bottom that has the nut on it, is tight. You can also remove that and make sure the float is not stuck or saturated with gasoline.
Jan 22, 2016 | Garden
I have a ryobi leaf blower that is leaking gas. It seems to be coming from the carb. The leak started when I changed the fuel lines. I then cleaned out the carburetor. It ran fine for one day and now the...
It sounds like maybe you tore the gasket that attaches the carb to the block. Check that, Also make sure your screws holding the carb. in place are tightened.
Mar 10, 2015 | Ryobi Garden
Yardman 27cc 445cfm Backpack Blower starts fine, but when I try to depress the trigger for more power it dies. Idles smooth with full choke and dies when on no choke setting. Have had someone say it needs...
There may be a plugged fuel filter in the fuel tank, or perhaps you have the oil mix to rich. other problems could be that it needs a new spark plug or carburetor adjusted.
Try spraying the carb out with carb cleaner, add a little seafoam in with the gas.
Oct 21, 2013 | Mtd Products TB2BP EC 27Cc Backpack Blower
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Wont start only used one time warranty is out changed spark plug /plug is firing can lay on side of engine and arcs at gap/took off muffler its clean tried to crank with out it on no luck/disconnected off...
I would recommend looking at the exhaust side of the piston and checking it for scoring. This unit is meant for no more than 50-75 hours of use. My guess is that you did not use it one time for 75 hours straight so I would recommend a new carburetor and fuel lines.
To check this you can modify an irwin clamp with a nipple to pressurize the inside of the carburetor.barterjoe_0.jpg If air leaks out of the check valves in the brass fittings of the metering chamber they need to be cleaned In a jewelry cleaner or just replaced as a whole carburetor. $30-40 for the cleaner vs $40-50 for a new carburetor and lines. barterjoe_1.jpg
call a local shop like www.arcolawn.com to get details about the special tools to test carburetors or to get carburetor parts. They may even be willing to clean your carburetor if you ship it to them. Good luck Joe
Feb 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
1995 Yardman 7 hp Snow Blower wont start. Ran fine last year and I drained the gas out. I cleaned out the carburetor, (tecumseh HSK70) 632371A. The top screw was 1/8 out from closed and bottom screw...
my 7 hp tecumseh yardman snowblower wont shift into gear worked fine but shifted hard (20 below) then wouldn't shift at all (loose) I noticed a rod that goes through the area where it shifts is loose (not connected) what is this rod. thanks for your help.
Jan 21, 2011 | Yard Machines Garden
Yardman snowblower wont start
More often than not, old gas in the carburator breaks down. It turns green and smells like turpentine. This usually fowls the carb inlet. I dodnot know the technical name but You can usually solve the problem by removing the bolt that holds the bottom of the carb. to the carb. It looks like a very small tin can under the carb. This contains the carb float and lets gas into the carb. The bolt is usually hollow and has two extremely small holes that allow gas to be taken up to the carb venturi. They are usually clogged and therefore no fresh gas gets through into the chamber. Use a very thin wire or needle to clear debri. Clean out old gas and residue before reassambley. It could also be the Carb float stuck closed and again no gas is getting through. You can service these issues usually without taking the carb off the motor.
Dec 19, 2009 | Garden
Blower
You need to rebuild the carburetor. Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then under select OEM select Homelite then do as instructed. You should find the parts you need and hopefully the parts breakdown for the carb. this will help you in the rebuild. If it does not have the parts breakdown for the carb. find what mfg and model carb. it is then go to that site for breakdown.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
32 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
