Question about Datsun Vehicle Parts & Accessories
Length oil dipstick
1200 datsun oil dipstick lenth
    Problem Solver:
  • 19 Answers
It will depend upon the engine manufacture date. The lengths are different between early and late A12 engines.
Short: ~9-1/16 inches from tip to bottom of rubber
Long: ~14-3/4 inches from tip to bottom of rubber
Posted on Aug 22, 2014
I want to put new oil into my yamaha XJR 1200 motorcycle but im unsure where to put it
Hi Diane,here's a Yamaha,might be similiar to your's,see the Yamaha letter's,above the a is where the dipstick is,have the bike level,pull out,wipe clean,then put back in and check. yamaha XJR 1200 motorcycle oil dipstick location Google Search
Aug 17, 2015 | Yamaha Motorcycles
1974 harley oil dipstick lenth?????
Hi, go to your nearest parts agent and get the info from him, don't leave it, if the dip stick is not for your engine you could suffer some real problems. Hope this helps, P
May 19, 2014 | Harley Davidson Motorcycles
OIL IS SHOOTING OUT OF THE DIPSTICK FROM THE OIL PAN.
Click here to see.http://www.autozone.com/autozone/parts/AZ-Filters-PCV-Valve/2003-Nissan-Datsun-Altima/_/N-jklw9Z8gd7h?itemIdentifier=926641_0_0_
Nov 11, 2012 | 2003 Nissan Altima
How do i put oit in a 2005 harley sportster 1200
Hi Anonymous, the engine oil dipstick on Softail and Sportster models is located on the right hand front side of the oil tank and the Harley Bible says, engine should be at normal operating tempurature, let idle on jiffy stand for two minutes. Shut off engine and hold bike straight up and dipstick all the way in, correct engine oil level will be at the top full mark. Do not overfill oil tank as this will cause engine breathing issues. On Dyna and Touring models The engine oil dipsticks are located on the right front top corner of the transmission and the engine oil pan is underneath the transmission. The engine oil level is checked in the same manner as Softails and Sportsters. If you are having oil carryover or breathing issues (dipstick launch) try running oil level half way between the add and full marks, running the engine at this oil level will not harm normal operation. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 28, 2012 | 2005 Harley Davidson XL 1200 C Sportster...
My datsun 1200 motor is blowing oil through the pollution hoses into the air cleaner what would cause this
possibly blowby. this can be caused by worn piston rings. I would suggest you run a compression test.
Feb 20, 2011 | Datsun Stanza Cars & Trucks
Where's the oil dipstick for a 1984 honda goldwing 1200 aspencade?
Hi, Stherustyone for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Where the oil dipstick for 1984 honda goldwing 1200 aspencade Google Search
Checking GL1200 oil level
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Aug 06, 2010 | 1984 Honda GL 1200 Aspencade Gold Wing
How do I check oil level on Trophy 1200 please?
either by looking at oil sight glass on casing of engine normally on the right should be 1/2 - 3/4 full or by a dipstick oil should be touching line
Aug 22, 2009 | 2002 Triumph Trophy 1200
Change head gasket 1974 Datsun 620 pickup
As far as compresion goes it is more important that all cylanders are close to each other than what the actual psi is they should be within about 5 psi of each other. When changing the head gasket on the 620 you need to make sure that you wedge the timing chain so that the chain tensioner does not pop out. If it does you need to remove the water pump and front engine cover to replace it. A 6 inch long piece of wood tapered from about 1 inch to about 1 3/4 inch should work. Other than that it's a very easy and straightforward job. I would recomend that you take the head to a machine shop and have it checked for warp, if the engine has been severly overheated it can cause the aluminum head to warp. I know this from personal experience. If there is some warpage just have the machine shop machine it back to flat so that the new head gasket dosen't leak. If you are getting oil comming OUT of the dipstick tube replace the PCV (positive crankcase ventilation) valveThe 620 is a great little truck and the L16 L18 and L20 engines were all very easy to work on and well designed. The downfall of almost all Datsuns was body rust.
Oct 18, 2008 | Datsun 210 Cars & Trucks
Vehicle Parts & Accessories Logo
88 people viewed this question
Top Datsun Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Datsun Vehicle Part and Accessory Expert? Answer questions, earn points and help others
