Question about Sony VAIO VGN-SZ280P/C Notebook
Pcg 41217l anakart
Wi max driver
REPLACE POWER JACK
http://www.ebay.com/itm/pcg-41217L-sony-vaio-DC-JACK-POWER-JACK-FOR-Input-Port-Socket-vpcsc-VPCEL-VPCF-V-/370628762815
Has two channels on the sides, to slide down into a channel formed in the outside edge, of the laptop Base Enclosure. (Bottom Cover)
Wires are soldered to it. Two of them. If there is a Red wire it goes to the Center terminal on the back of the jack. The Center hole is the Positive connection.
The Black wire goes to the outside terminal on the back of the jack.
(Negative)
Use good de-soldering/soldering skills. Do not make a cold solder joint. (Solder connection)
There are no exact Service Manuals listed for the Sony VAIO PCG-41217L Notebook PC. (It is also part of the VPCSC series. It is a VPCSC31FM)
However after you disassemble 100 laptops, or so; you find disassembly of all laptops follows a basic pattern.
http://www.ebay.com/itm/Sony-Vaio-vpcsc1afm-pcg-41217l-s-series-laptop-I5-blu-rau-MS-OFFICE-installed-/271101863505?pt=Laptops_Nov05&hash=item3f1eee2651
This shows me different key views of the laptop. I have also opened a separate window, with the User Guide from Sony eSupport.
The Ebay link shows detail of the Palm Rest Cover.
Shows it to be one piece with no separate Switch Cover.
(Switch Cover: Flat plastic strip above Keyboard, and below Display Assembly.
Usually has the Power On button, LED indicator lights, speakers, etc in it)
Also shows me a Bottom View.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Lay the notebook on a clean, static free cloth, on your table.
Helps protect the table, and the laptop from scratching.
Lay the notebook bottom side up, Battery Compartment facing away from you.
Use a multi-compartment container, and label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
You should be wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Average cost is around $3 to $6. Do not wear it, and/or connect to a good ground source, and when you are finished you can use your laptop for a doorstop.
Static 'kills' computers.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is unwarranted.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
You are going deep into the laptop, and the Static sensitive Processor, and other hardware components could be 'zapped'.
Use ESD wrist strap.
All screws are removed from the bottom of the laptop. All around the perimeter (Outside), and the inner ones.
The optical drive (CD/DVD drive) will slide out.
After the optical drive is removed, look to see if there are any hidden screws on the outside edge of the laptop, that may have been covered by the optical drive. Remove them if so.
Remove the Harddrive.
Remove the Ram Memory.
Remove all peripheral components. (Dummy PCI card, etc)
I don't know if the Palm Rest Cover removes on this model, or the Bottom Cover. (Base Enclosure)
Bottom Cover removal style,
http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-cs215j-laptop-replaciong-dc-jack-harness/
Yes. The bottom cover access panels are different than yours.
Posted for Keyboard removal, and Bottom Cover removal.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard. There is NO plug connector on the end of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
It ONLY plugs in, in one direction. Must go back the same way it was originally. Even if it was originally twisted.
For this reason you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two separate pieces, but DOES NOT come completely apart.
There is a larger rectangular Bottom part. This is the Body, and it is stationary. Mounted to the motherboard, and doesn't move.
There is a smaller rectangular piece on Top.
This is the Locking Bar.
There are two styles presently used;
1) This style slides. Slides up towards the LCD screen.
ONLY slides about 2mm. That is a little more than 1/16th of an Inch.
A) Closed, or can be said as Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Open, or Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
The Locking Bar is barely seen on top, and the sides. The 'tabs' of it on the sides, are eased towards the LCD screen, with the thumbnails.
2) This style flips up,
A) Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
2) Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
IF, the Locking Bar is removed from the Body, it is broken; or the Body hinge pins are broken.
EITHER way means MOTHERBOARD REPLACEMENT, and why I am being so detailed. Use care.
Here is what the Keyboard looks like,
http://www.ebay.com/itm/SONY-PCG-41217L-Keyboard-Silver-/261121017591?pt=PCA_Mice_Trackballs&hash=item3ccc0686f7
Put your mouse in the middle of the photo, and slide to the right side of the Keyboard.
See that half-moon tab sticking out, that looks to have a threaded hole in it?
Screw comes up from the Bottom of the laptop, and goes into this tab.
Looking closer at the open laptop view of the Keyboard, it almost looks like the Keyboard is under the Palm Rest Cover, and cannot be removed until the Palm Rest Cover is removed.
May just be the view, or my eyes.
That is about as far as I can take you.
Post the problems you run into in a Comment, and we'll try to work them out together.
Regards,
joecoolvette
[ Just in case it will help,
http://www.insidemylaptop.com/category/7-sony-laptops/
Nov 11, 2012 | Sony VAIO Computers & Internet
TL-WN822N WIRELESS N ADAPTER I CANNOT USED ON MAX WHY?
It's probably because the OS does not have the drivers for it. Did TP-Link include drivers with the adaptor? Also, what model Mac are you using as Macs have had AirPort cards (Apple's name for their Wi-Fi cards) since 1999.
Aug 20, 2012 | Apple Genuine Iwork 09 For Mac, Mac Os X,...
I have a red light on my abitIN9 32x-max motherboard and I couldn't not figure out the problem.
If you don`t have a manual down load one here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IN9+32X-MAX+Wi-Fi&fMTYPE=LGA775&pPRODINFO=Manual
Here you also find drivers for your product.
The red light fault could be:
Bad or outdated driver for the graphic card, or for the mainboard.
Graphic card failure.
Ram failure.
CPU failure.
My solution is to upgrade all the drivers there is outdated.
If this does not help your mainboard has an internal failure.
Hope this will help you.
Mar 20, 2011 | Abit IN9 32-MAX Motherboard
A driver for sony vaio pcg-k23. i lost my installer cd. ican't find a driver.
go to goole, type driver max, and download that program, u will need to sign up but the program automatically identifies ur drivers and downloads them and installs them for u
Nov 21, 2009 | Sony VAIO PCG-K23 Notebook
I don't have a driver installer
u actually dont need a driver installer, u can just install the driver one by one by urself but if u absolutely need one, then u can use Driver Max, u can download all the driver for free and it is very easy to use and u can also install drivers
Sound problem
look for the driver of your sony.. it always available on the website donwload page.. just check your model..
Aug 25, 2009 | Sony VAIO FR130 Notebook
Max memory allowe
Sony Corporation Model : Q-Project 02 ... Sony VAIO PCG-K23 Memory Max is 1GB
Jul 22, 2009 | Computers & Internet
ASUS P5VD2-VM
please send me audio driver for Asus p5vd2-vm mother board
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Sony PCG-9G1L Wi-Fi Drivers
Look on driverguide.com for them, either by the make and model of the laptop, or the wireless card. You sometimes have a better chance of finding wireless drivers or updated drivers by the make and model of the wireless card.
Aug 26, 2008 | Sony VAIO FXA63 Notebook
Sony VAIO VGN-SZ280P/C Notebook Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
