Question about Laney Prism Modeling Amplifier Combo - P20
Laney Prism - Laney Prism Modeling Amplifier Combo - P20
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
Hiss on laney A1
What is the impedance on the devices? It sounds to me like the amp and the pickups are not rated for each other.
Dec 16, 2013 | Laney A1 65-Watt Acoustic Amplifier with...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
Why are there two jack input connection in the back in the Laney RB 410 speaker cabinet?
The second jack which is present on MOST speakers is for daisy-chaining a second speaker. One has to make sure to NOT go below the minimum impedance allowed by your amplifier. Often this minimum is 4 ohms which allows TWO 8 ohm speakers to be connected to the 4 ohm output.
Feb 03, 2011 | Laney RB410
My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Mar 25, 2009 | Music
Laney Prism Modeling Amplifier Combo - P20 Logo
21 people viewed this question
Top Laney Music Experts
rhodesworks
Steve F
Are you a Laney Music Expert? Answer questions, earn points and help others
