Question about La Crosse Technology TX61U-IT Solar Powered Wireless Temperature Sensor
Outside temperature is blank. How do I fix sensor?
Where is the ambient temperature sensor located ?
images for 2008 Chevrolet HHR LT Where is the .
Outside Temperature Sensor - Chevy HHR Network
www.chevyhhr.net/forums/...hhr-4/outside-temperature-sensor-30594/
Jul 9, 2010 - I had the outside temp sensor go on my 99 Buick. I don't know where it islocated on the HHR, but it was just a plug in sensor. Take out the old, stick in the new.... 2008 HHR LS 2.2 L Auto Built: 12-19-2007. Bought: 4-26-2009 Location of the ambient engine temperature sensor.... Help ...
Mar 26, 2013
Engine Temperature Sensor
Oct 6, 2011
Outside Temp Display
Dec 19, 2008
Outside air temperature problem
Oct 30, 2007
More results from www.chevyhhr.net
Jan 25, 2016 | 2008 Chevrolet Chevrolet HHR LT
Tip
How to fix the outside temperature gauge
A common problem on Hyundai vehicles is the outside temperature reading in their dash stopped working or displays incorrect temperature. The models in question with this fault are the 2011 Santa Fe, 2013 Sonata, 2013 Elantra.
The problem lies in the wiring harness along the bottom of the rad saddle (bottom/center of rad ). The ambient sensor is located near the horn in front of the rad. Examine the ambient sensor for damage and them follow the two wire down to the bottom of the rad, open up the harness and you will fine a break in the sensor wire from corrosion/ moisture. Repair/ solder in new piece of wire and heat shrink.
on Feb 23, 2015 | 2011 Hyundai Santa Fe
I have. 2005 Chrysler 300c that is throwing engine code p0072. What exactly is it and can I fix it myself?
Error Code: P0072
Description:
Outside Air Temperature Sensor - Low Input
Possible Cause:
- Wiring short to earth.
- Outside air temperature sensor faulty.
- Engine control module (ECM).
Apr 16, 2015 | Chrysler 300C Cars & Trucks
The outside temperature gauge on a 2009 g5 Pontiac is not reading right how do you fix it
There is a outside temp sensor mounted on the radiator support in the front of the car,sensors get dirty or just fail
Dec 05, 2014 | 2009 Pontiac G5
I have an open circuit error and would like to fix it.
I would measure the resistance of the temperature sensor behind the grill. If its open, the sensor is bad. If it shows resistance, then you probably have a broken wire somewhere.
Jul 23, 2014 | 2000 Jeep Grand Cherokee Laredo
Lexus ES300 outside temperature gauge not working
I also have the same problem, I would also be happy with a diagram of the location of the sensor.
Jan 08, 2010 | 2002 Lexus ES 300
Climate Control Outside temperature display incorrect
you need to replace the ambient temperature sensor or do the math
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Temperature display
Most likey the sensor is the issue, it is located in front of the radiator on a little metal bracket, it has 2 wires going to it.
Nov 08, 2008 | 2002 Buick Regal
La Crosse Technology TX61U-IT Solar Powered Wireless Temperature Sensor Logo
43 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
