Nad 317 Start problem, no power.
I have a NAD 317 Power amplifier. When turning on power, relay RL201 start to "click", but dont seem to connect.It just stay on clicking. This is a problem that is comming and going? No and then it works perfect. There are also two zenerdiods, D657 and D658 that gets very hot, on the "input,standby led & led PCB"! It seems like a periodic problem?? I am educated radio, TV and electronic engeneer, but have for many yaers worked with data software. Still I like to keep my repairknowledge in shape. Frendly regards PGB Norway
  • Anonymous Apr 06, 2008
    LE CONTACT POUR METTRE EN MARCHE LA RADIO NE FONCTIONNE PAS . JE L`AI BRANCHER ET RIEN NE FONCTIONNE .IL EST NEUF.
    ET JE N`AI PAS DE GUIDE UTILISATEUR.
  • Gertjan Jan 27, 2009
    I have the same problem with my NAD 317.
SOURCE:
SOURCE: NAD 705 out if order
As the display lights are blown, you can't see that the unit is in the wrong 'listening' mode. USe the Listen switches to get to the input you are tring to use. The blown lights can be replaced with White or Blue 'wide beam' LED's, one leg connected in series to a 6k-ohm resistor.
Posted on Feb 13, 2008
marsrover
  • 682 Answers
SOURCE: Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Posted on Aug 24, 2008
SOURCE: Cant get it to power up
I had exactly the same problem. Here is how I resolved it. 1. There is a reset button inside the battery compartment, in the center, between the C cells. Try pushing it with a paper clip or similar item. 2. If that doesn't work, replace the C cells. 3. If that doesn't work, try replacing the lithium backup battery. It is located between the C cells, in a compartment with an arrow. 4. I finally did all three at the same time, replacing the C cells, lithium battery, and resetting the system. The radio has worked fine for two days now. Good luck.
Posted on Dec 09, 2008
SOURCE: NAD 304 power indicator
Change resistors 333 & 334 - 47k-1W
Posted on Jan 04, 2009
SOURCE: volume control
If you did not fix this, I would like to purchase the antenna from you. My ex wife returned my radio with a missing antenna! So please email me at [email protected]
Posted on Aug 20, 2009
Nad 317 protection mode
Assuming the protection circuit is not faulty, I would look to the devices on the heatsink to the cause of the fault.
Jul 29, 2013 | NAD Audio Players & Recorders
Nad 317
Check for leaky output transistors change emitter resistors
Amp shorts down during "Warm-up"
These needs repair.
Check for shorted drive / output transistor and associated circuits.
Aug 29, 2012 | NAD C270 2-Channel Amplifier
No sound from my NAD C325BEE amplifier
audio ic problem or component around audio ic.. good luck
Apr 26, 2010 | NAD C325BEE Amplifier
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Nad 317 Amplifier No sound
Could be the speaker output relays. GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
Nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Feb 06, 2008 | NAD C370 2-Channel Amplifier
Jan 05, 2008 | Audio Players & Recorders
NAD C340 has lost ability to switch between inputs
I have the same problem which started about a month ago and seems to be getting worse. I also noticed today, that 1 channel is significantly louder than the other - fault in the pre-amp stage, as feeding the power stage directly gives balanced, albeit extremely loud sound! Looking on eBay, I found someone else selling an amp with both problems. It would nice to think that NAD would acknowledge a design flaw, and fix for free, but my amp is 5 year old.
Jul 14, 2007 | NAD C340 Integrated Amplifier
308 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
