Question about Vacuums
Electrolux c134d hi, i need the wiring diagram as i diassemble the vacuum hose and mixed up the wiring thanks
  • 15 Answers
SOURCE: vacuum hose replace electrolux how to
YOU DON'T SAY IF YOU HAVE THE NEWER HOSE OR THE CLASSIC ONE WITH THE STEEL TIP (BETTER DESIGN). IF IT'S THE LATTER UN-SCREW THE SCREW CLOSEST TO THE STEEL TIP,TAKE A SMALL SCREW DRIVER AND LIFT THE THE PIECE OF PLASTIC THAT WAS SCREWED DOWN JUST ENOUGH TO SLIP THE HOSE OUT.
WHAT YOU'LL BE FACED WITH IS SOMETHING I WOULDN'T SUGGEST CUTTING.
IT MAY BE MORE PRACTICAL BUYING A NEW HOSE. AN ELECTROLUX WILL LAST FOREVER,BUT YOU DO HAVE TO REPLACE THINGS LIKE THE COMBO DUST/UPHULSTRY ATTACHMENT. THE HOSE IS PROBABLY THE FIRST THING YOU WOULD NEED TO REPLACE BECAUSE OF AIR LEAKS. I'VE HAD MY OLYMPIA ONE FOR 27 YEARS AND HAD TO REPLACE THE HOSE ABOUT 10 YEARS AGO. YOUR CHOICE.
Posted on Dec 02, 2007
  • 3 Answers
SOURCE: electrolux 2100 canister vacuum
Open the door to remove the bag. Pull the side bumpers forward when the door is open. The profile of the edge of the top and the bottom of the vacum body is a "L" shape. The cross section of the bumper is a "I" and that holds the body together. Carefully lift up the top just a little to free the plastic end cap that conceals the cord spool. There are two plastic pins on the top and bottom that hold this piece on and they frequently get broken. (If that happens repair shops drill and hole and insert a screw.)
There is a plastic protector plate that lifts up on either end and then is slid about 1/8th inch clockwise and then up.
Copy the wiring pattern on the four male connectors on the motor and the wire spool.
Post your wiring diagram and it will solve a lot of people's problem trying to reassemble this machine's -- including mine.
Posted on Jan 07, 2008
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
  • 15 Answers
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Posted on Jun 17, 2008
I have electrolux central vacuum that has power to vacuum but not to the power head or side kick.
The wires that power the accessories are an integral part of the hose. Test the connections with an ohmmeter to be sure before buying a new hose.
Mar 12, 2016 | Electrolux Vacuums
Wiring diagram
The only place I know of fora wiring diagram for a Guardian is at the local branch office. The new name for the Electrolux is now AERUS.
Check your phone book.
There is a fuse wire that runs from the cordwinder to the triac circuit board inside the vacuum canister. You have to take the six screws out of the bottom. Open the bag door and lift up on the top handle to remove the top part.
It is vere advisable to take your vacuum to the branch office that has a qualified service manager. You can do more harm than good on the inside of the machine.
Jul 22, 2014 | Electrolux Guardian Bagged Canister Vacuum
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
When I vacuum with the power nozzle, it keeps cutting off. Do I need to replace the hose or the power nozzle?
Not necessarily. It's hard to tell without checking it out. I strongly recommend taking it to an authorized Aerus Electrolux store and letting the service tech check it.
If you have the "Sidekick", you can try using it. If it still cuts out, it's the hose. If not, the wiring in the power nozzle is loose or worn and needs to be replaced.
Keep in mind that you may not need to replace the hose or power nozzle, just have some wiring repaired.
Nov 07, 2010 | Electrolux Epic 6500 Vacuum
My vacuum hose has split very close to the handle- how do I remove the handle, cut the hose at the split & reattach it to the handle unit - Centralux central vacuum system. Where can I find a diagram...
Do Not Cut the hose!
It has wiring inside to control the vac and power head. This is a swivel handled hose with both low and high voltage contacts in it. The same wiring which gives the hose its ribbing, is conducting current for two applications,
If your hose has a switched handle, a very experienced, trained AERUS Electrolux tech will a have a tough time doing this job and will likely refuse as it is not recommended per company policy.
You can purchase a shrink wrap tube which will prolong the life of the hose if it has not collapsed, however this is a short term fix.
I could walk you through this as I have done it before ...Unfortunately, even if you were able to dismantle the hose successfully you would not be able to purchase the wire terminals which you would cut off the end when shortening . Sorry its a proprietary part.
Sep 20, 2009 | Electrolux Centralux Vacuum
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vacuum
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
