Question about Samsung UN46ES7500 46 inch 240hz 1080p 3D Wifi LED Slim Mount
Samsung UN46ES7500 46 inch is turn off and on every 15 min
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
42 inch samsung plasma comes on then picture go's out turn off and back on the picture comes back on and go back out after 30 min
It sounds that the Va / Vs voltages to panel has gone out of its range. Check these voltages. If you wish to get more details about these voltage settings, check this link.
Feb 05, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
Samsung HL P6163W turning it self off after 15 min.
Do a factory reset to this set. If sleep timer function is set to 15 minutes, the set will turn OFF by itself after this time.
May 16, 2012 | Televison & Video
I have no signal for 48 hours my other samsung mobile is ok please help
hello there!
i can help you with your problem. just follow these easy steps:
1. turn off your mobile phone.2. remove the battery, sim card, and memory card ( if you do have ) of the mobile phone.3. wait for 15 mins.4. after 15 mins of waiting, put in back the battery, sim card and the memory card. wipe first the sim card and memory card before putting in.5. turn on your phone.
I'm pretty sure that after turning on your phone you will do have a signal.whenever you encounter this again, just do this procedure.
kindly rate this post and thank you for choosing fixya.
Jan 25, 2012 | Samsung Star GT-S5233 Cell Phone
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung 42' flat panel tv wont turn on
It sounds like some capacitors have failed on the power supply board. Samsung is covering this repair under a special warranty. You can call 1-800-samsung to find out if your unit will be covered.
Mar 22, 2010 | Televison & Video
I bought this on clearance. I hooked it up and
Samsung LN40A550 LCD TV
This is probably the LCD Controller (T-CON) board connections. This is a small board with 2 flat cables connected to it which run to the LCD screen. The connections with the flat ribbons needs to be reseated. The heat makes the connections misaligned. This board is usually covered by a metal shield.
When you reseat the connections, run the set for 15 minutes to see if it works before replacing the back cover. You may have to reseat it again.
Remember, handle electronics boards by the edges, no static electricity, and do not touch the connection contacts.
At worst you would need a new board. (Shopjimmy.com has it for ~$90.00usd)
May 09, 2009 | Samsung LN40A550 LCD TV
50 inch samsung flat screen television
fan # 2 is having problems; maybe missing voltage or broken fan
good luck
Sep 10, 2008 | Samsung TXM3297HF 32" TV
Samsung UN46ES7500 46 inch 240hz 1080p 3D Wifi LED Slim Mount Logo
Jerry Greenberg
Jerry Greenberg
