Question about Powermate 79 cc Walk Behind Gas Edger
Powermate lawn edger. Pwle0799 - Powermate 79 cc Walk Behind Gas Edger
Is there a lawn edger attachment for a florabest multi tool
No. However if you can rotate the string trimmer 90 degrees you can use that as an edger. Just be careful as the guard may not offer much protection from flying debris.
Jul 27, 2016 | Garden
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
How do I reset the governor on this engine. The locknut slipped loose and it is off.
Get someone with a photo tack or electronic tack pick up to record engine RPM and adjust the engine to proper high RPM
Nov 04, 2015 | Powermate 79 cc Horizontal Gas Edger
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Replace line
Two possibilities:
1. Buy a new spool. Make sure you bring your make and model/size to the store to get the correct replacement spool, or
2. Buy new line and manually wind it into the existing spool. Smaller lawn trimmers and edgers use smaller diameter line than larger lawn trimmers and edgers.
Good luck.
Paul
May 31, 2015 | Garden
Where can I get an edger blade
any home improvement store that sells lawn equipment
May 17, 2014 | Mtd 25B-520D200 CA Gas Lawn Edger
Are you supposed to sharpern the blades on the edger occasionally
Hello:
No. Edger Blades are Not Sharpened.
Respectfully
John
May 09, 2009 | Black & Decker Le750 Lawn Edger
Starting the Coleman Powermate 5000 generator .....
Thanks for the offer of the Premium Assistance Plan, but no thanks -- I was able to get the answer from a local department store from their "lawn & garden" center....
J
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Powermate 79 cc Walk Behind Gas Edger Logo
116 people viewed this question
Top Powermate Garden Experts
Dennis Key
Dennis Key
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
