Question about Maytag Washing Machines
Maytag bravos xl top load shows sd code. checked everything. ran cleaner thru, ran hot water thru, ran vinegar thru, tore completely apart cleaned the inside of the outer drum which wasn't dirty, took off cover for pumps (also inside outer tub) also clean. ran diagnostics f80 and f71 codes flashed through. lid locks just fine-did manual test again for that anyway. doesn't want to go into low spin, clicking noise from the motor under the machine during diagnostic. when try to run a wash at 14 min remaining the sd code comes up and the wash selection band flashes, and basically stops before rinse and high spin. agitates fine.
SOURCE: maytag fav6800aww wont spin
I have a 3 year old neptune top load and have experienced the same problems you all have had here. Problem: Washer was leaking 1/2 gallon of water every load and sounded like a freight train on spin cycle. I usually do my own repairs but didn't have time so I called A&E by the recommendation of Maytag. Diagnosis! The tech said the tob o-ring seal was bad as well as the transmission. I had no reason to dought this professional right. I did after he told me the price... $450 to fix it!!!! I reluctantly gave him his $65 service call fee and said goodbye..
I called maytag and they said the transmission should have been covered by warranty (10 years). The tech was either an idiot or just plain trying to rip me off. I called Maytag back and they sent me the supposed bad tranmission and seals. I replaced them in 1/2 an hour. Guess what.... This did not fix the leaking or the loud spin cycle noise. What is the problem with this neptune model? The problem for every owner including myself has at minimum been the main seal inside the outer tub. This leaking for months took out the bearings causing the noisy spin cycle. I replaced both 6207-2rs bearings compliments of ebay for $6ea. After reassembly it was like new for the first load. On the second load it would stop on the spin cycle.... It would cycle between the agitators and trying to spin but never engaging into spin. After 5-6 minutes it gave me the code that stated an unbalanced load. What the problem was is the leaking had made its way into the clutch as well. I pulled the clutch/pulley back of and cleaned and lubed it. Problem solved! She now goes into spin and has no problems whatsoever. I'll never call A&E again...Mechanically this washer is a piece of cake to work on. Electronically it could be a bear... The bearing replacement took approx. 2 hours total from start to finish. Next time I'm buying Kenmore and the extended warranty. I'm tired of screwing with this junk... Good luck guys.... Jos Roach... CA.
Posted on Jan 19, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 151 Answers
SOURCE: I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Posted on Dec 24, 2009
SOURCE: Siemens WFXD5201UC Front Load Washer won't complete cycle.
I am having the same problem with my washer. Did you ever get it fixed??
Posted on Mar 26, 2010
SOURCE: Maytag Bravos washer rattles when it hits rinse cycle and will no
Mine is doing it. What was your final result?
Posted on Jul 17, 2010
Every other wash sd code come on
The SD error code is caused by using the wrong detergent or excessive amounts of detergent.
To correct the issue: Make sure to use HE detergent. Note: Using Non - HE Detergent will cause oversudsing and can damage the washer. Do not use too much detergent.
Note: If using HE 2x - 5x concentrate detergent, reduce the amount being used. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed without detergent.
Feb 18, 2013 | Maytag Bravos MTW6600T Top Load Washer
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
Can i use vinegar instead of fabric softener? would it harm the mashine?
I cant imagine vinegar harming your machine, if anything it would clean it! But i can imagine walking round in vinegar smelling clothes phewww :-)
Mar 22, 2010 | Maytag Bravos MTW6600T Top Load Washer
I have a maytag bravos washing and it keeps giving me a code of sd but i have never used ne soap other than he soap. i have tried everything. i can run the clean washer mode and it goes fine but when i...
Your code Sd is most likely related to 'slow drain', which can be the pump in the machine or the drain behind it. Check to be sure the drain is clearing quickly enough and if so, have the pump on the washer checked. In the meantime, if you hit cancel and let it sit a bit then hit start, it should take right off and finish the cycle. Hope this helps!
Feb 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Where do i have to clean it at?
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. And if you were getting the Sd code it should also be gone. You can also reset this by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Oct 11, 2009 | Maytag Bravos MTW6600T Top Load Washer
Strong mildew smell coming from washer
Try running a cup of white vinegar thru a wash cycle w/o clothes.
Jan 28, 2009 | Maytag LAT2301AAE
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
