Question about Garden
Need manual for RST OP-PECLB7-CAN-K for warranty information
Where can I get an instruction manual for a SunFish Kulsns womens bicycle. r4677
You don't need a specific manual, as parts and adjustments are the same for bikes of the same style. In addition bike manuals have mainly safety information and very basic other information. Just go to a bike shop and ask for a manual for your style of bike. If that does not provide the info you need look into repair classes at a bike shop or bike co-op or look up the procedure you need to do with Google or at: Repair Help and Education
Jul 21, 2017 | Cycling
How do i turn the fuel off my gilera runner 50cc
Hi, Shane for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Gilera, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GILERA Runner fuel leaks
Fuel shut off installation converting from vacuum to manual
Gilera Runner RST 50 SP Service Station Manual
https://www.oemmotorparts.com/oem2.asp?M=gilera
http://www.eumoppenomc.se/WebRoot/Ballou/Shops/moped/4E2E/640B/3A3C/9A86/C6E0/0A0C/05E9/B1B7/Manual_GILERA_Runner_SP_50.pdf
Mar 18, 2017 | Gilera Runner VX 125 Motorcycles
Gilera Runner Lights Don't Work I've replaced everything I can think of and still nothing. Normal bulb from the front is missing? is this needed to complete the circuit? No other idea why!!
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Gilera, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.cr-service.se/Piaggio%2050%20cc/Service%20manual/PIAGGIO_MSS_RUNNER%20PJ.pdf
http://boonrod.com/files/misc/files/Gilera%20Runner%20ST%20200.pdf
Jun 18, 2016 | Gilera Motorcycles
Need op manual for 16069360001
Need more information. What brand ,model, year.
Bob
Jan 16, 2015 | Televison & Video
Lowering the bike
Hi, Anonymous here are some options for lowering your bike depending on your needs and wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue, please visit the websites below. Good luck and have a nice day.
DOWNLOAD 2004 Aprilia Rst 1000 Futura
Nov 24, 2013 | 2004 Aprilia RST 1000 Futura
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 | Watches
How to connect from jsp login page to database
hey try this code......just found it on the net... Put the code in tomcat and test the application through browser. The browser should display the display the data stored in the table.
Here is the code of our JSP file
<%@ page language="java" import="java.sql.*"%>
<html>
<head><title>Read from mySQL Database</title>
</head>
<body>
<p align="center"><b>Following records are selected from the 'jakartaproject' table.</b><br>&nbsp;</p>
<div align="center" width="85%">
<center>
<table border="1" borderColor="#ffe9bf" cellPadding="0" cellSpacing="0" width="658" height="63">
<tbody>
<td bgColor="#008080" width="47" align="center" height="19"><font color="#ffffff"><b>Sr.
No.</b></font></td>
<td bgColor="#008080" width="107" height="19"><font color="#ffffff"><b>Project</b></font></td>
<td bgColor="#008080" width="224" height="19"><font color="#ffffff"><b>Url
Address</b></font></td>
<td bgColor="#008080" width="270" height="19"><font color="#ffffff"><b>Description
of the project</b></font></td>
String DRIVER = "org.gjt.mm.mysql.Driver";
Class.forName(DRIVER).newInstance();
Connection con=null;
ResultSet rst=null;
Statement stmt=null;
try{
String url="jdbc:mysql://192.168.10.2/tutorial?user=tutorial&password=tutorial";
int i=1;
con=DriverManager.getConnection(url);
stmt=con.createStatement();
rst=stmt.executeQuery("select * from jakartaproject ");
while(rst.next()){
if (i==(i/2)*2){
<tr>
<td bgColor="#ffff98" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffff98" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffff98" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffff98" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
}else{
<tr>
<td bgColor="#ffcc68" vAlign="top" width="47" align="center" height="19"><%=i%>.</td>
<td bgColor="#ffcc68" vAlign="top" width="107" height="19"><%=rst.getString(2)%></td>
<td bgColor="#ffcc68" vAlign="top" width="224" height="19"><a href="<%=rst.getString(3)%>"><%=rst.getString(3)%></a>&nbsp;</td>
<td bgColor="#ffcc68" vAlign="top" width="270" height="19"><%=rst.getString(4)%></td>
</tr>
i++;
rst.close();
stmt.close();
con.close();
}catch(Exception e){
System.out.println(e.getMessage());
</tbody>
</table>
</center>
</div>
</body>
</html>
Feb 27, 2009 | Compaq Computers & Internet
Urgently send me solution with diagram
Hi - Here is the diagram from the manual:
Hi - You can download the manual from the link below:
Manual
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 04, 2008 | ASUS K8V-MX Motherboard
Ms Access - OpenRecordset question
I think you just need to change it to read: Col_Title(iCount) = rst![F + iCount] from the original Col_Title(1) = rst![F + iCount]
Sep 19, 2007 | Microsoft Office Standard for PC
Garden Logo
493 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
