Question about BOSS AUDIO SYSTEMS 612ua
Installation tips for 95 honda civic - BOSS AUDIO SYSTEMS 612ua
95 honda civic was overheating stoped and wont turn on !checked ignition system no spark?
Check the radiator fan, check the radiator. Engine oil level or minus a lot ...
Tip: Do not try to move the vehicle until the vehicle is designed to transport cars broken
Jun 20, 2011 | 1995 Honda Civic
Civic brake lights
Yes,try pulling up the brake pedal with your hand,see if the brake lights go off,if they do,or they do not,the problem will be with the brake light switch on the brake pedal under the dash.
Jun 10, 2010 | 1995 Honda Civic
Improve a sound system on a honda civic 2008
good day Sir, try to install a sub woopers and amf. i hope this tips will help.
May 09, 2010 | 2008 Honda Civic
95 honda civic LX -Getting low gas mileage,
what is your milage now, how many miles, how does it run, city or hwy driving??
Mar 05, 2010 | 1994 Honda Civic
95 honda civic speedometer usually doesnt work
had the same problem w/ my 1995 honda civic lx. there is no speedometer cable in this vehicle. there is a speed controll sensor, if ur facing the front of the vehicle it is located on the left side just beyond the distributor cap/ below . its held by two screws. price range was about 75 to 125 ? i got my off a friends honda that no longer was running. bam! fixed
Aug 28, 2009 | 1995 Honda Civic
Where can I get wiring diagram for 92 Honda Civic LX?
Here several documents:
Engine wiring-1992-95 Civic (except VX)
Engine wiring-1992-95 Civic VX
Chassis wiring-1992-95 Civic, 1993-95 del Sol
Good luck... remember rated this help.
Aug 19, 2009 | 1992 Honda Civic
1989 Honda Civic hard starting and dies for no reason. Cooling fans not working. Trouble codes are #6 coolant, #10 air intake temp, #16 fuel injector. Can anyone lead me to a solution for these problems?
6
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
check your wiring for dirty connections or broken wires, you may have wires that are rubbed through or connectors that are not making full contact. you will need an ohm meter and check wires for continuity. a wiring diagram will be needed.
May 15, 2009 | 1989 Honda Civic
Uninstall Honda radio
Download the 93-95 civic service manual off hondatech.com.It should be able to tell you step by step all processes needed to take out the standard radio and install a new one,right down to the colour of the wiring and what they're for.
Jun 01, 2008 | 1993 Honda Civic 4 Door
BOSS AUDIO SYSTEMS 612ua Logo
13 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
